Re: OT : Thermostat . . .
JohnKJordan in East TN
>>Don't touch the red wire to the black wire or...
The control wires that run from my heat pump outside to the thermostat inside were pinched once and shorted the red wire to the frame. The AC quit in the heat of the summer. It was a mess to fix - after locating a wiring diagram and determining there was no 24-volt supply to the thermostat, I had to partially disassemble the outside unit to even figure out what was wrong. It turned out an internal fuse was blown. (no circuit breaker) BTW, this is a large commercial heat pump.
Of course, the fuse was a special part only available from a Trane service company. Of course, the local Trane service had a "no electrical parts sales" policy. Fortunately, the owner kindly gave me a fuse without charge which fixed the problem. Moral: don't short the 24-volt line! I'd thrown the breakers to power down everything to avoid the risk.
