arbor bearings
arbor bearings
arbor bearings
Paul in Kansas
>The arbor bearings on my 20+ year old Delta contractors saw are giving up. Any warnings or advice would be appreciated. Do I need to remove the table top to remove the arbor bracket? Thanks.
Re: arbor bearings
Re: arbor bearings
Pete in Holland, MI
>Did my JET tablesaw bearings last winter. Don't go to Delta. Take out the old bearings and go to bearing house. Much cheaper. Get "sealed" and not "shielded" bearings. They do a better job keeping the dirt out. My arbor had a threaded nut to keep the arbor within the two bearings. Be careful as you press the bearings in place so that they are fully seated, and draw up on the nut on the arbor, so as not to put too much side load on the bearings. The arbor should turn freely once installed.
Re: arbor bearings
Pics of how to do it... *LINK*
Jim Rahbe, Bedford, TX
>Paul,
I agree with Pete on buying the bearing through a bearing shop.
Attached is a link to a crude article on how I did mine..
Good luck,
Jim R.
Bearing Removal Pics
Re: arbor bearings
Re: Pics of how to do it...
Paul in Kansas
>Thanks for the info. It's starting to be less intimidating now. I was really dreaming to think I could do it with the table still attached.
Re: arbor bearings
Ummm, wait a minute...
>I have not done this, so I am talking off the top of my head, but you said you had a contractors saw. The one in the tutorial was a cabinet saw. (????) On contractors saws the mechanism hangs from the bottom of the top. On cabinet saws the mechanism hangs for the cabinet. I think.
I think you will have to turn your saw upside down to so this if it is a contractors saw, or you can remove the top and the tilt mechanism all at stone and turn it upside down. If you can do this without removing the mechanism from the bottom of the table, you may not get into alignment issues. (Making the blade parallel to the Tee slot, squaring the fence, etc. If you have a cabinet saw, replacing the top will require realigning it.
Re: arbor bearings
Re: Ummm, wait a minute...
Rick W
>Barry is right. On a contractor's saw, the whole arbor assembly hangs from the table. You have to turn the saw upside down to get at the arbor.
I did one over 20 years ago, and I don't remember everything I did, but I do remember having to turn it upside down to remove the arbor assembly.
I second the recommendation to buy your bearings from a bearing supply house.
Delta has a section on their website on re-aligning a contractor's saw.
Good luck with it!
Rick W
Re: arbor bearings
Barry is correct...
>Paul,
Sorry for the confusion. I read it was 20 years old and assumed it was a cabinet saw, even though you clearly said it was a contractors saw..
At least I can say I won't make that mistake again... in 2007.
Jim R.
Re: arbor bearings
Re: Barry is correct...
Paul in Kansas
>Thanks for everyone's input. In looking at this today, it appears that the arbour bracket pivots on a pin/rod held in place by a set screw. Remove the set screw, tap out the rod, and raise up and out the arbour bracket. Maybe. Since I have large wing extensions, and outfeed table, that will mandate that I have to turn this deal upside down. No need to start out the New Year in a pleasant fashion.
Thanks again. I appreciate the knowledge base here.
Re: arbor bearings
Re: arbor bearings
Robby Wright
>Paul - I have the same saw you have and changing the bearings isn't hard. First, remove the belt. Then, I remove the motor by removing the pin that acts as the pivot for the motor plate. I support the motor to the side on a bucket.
There is a set screw on top of the trunnion assembly that holds in a pin. Loosen or remove the set screw and slip out the pin,tehn remove the arbor assembly. I bought my bearings at a bearing house. They cost less than $10 a set the last time I bought them. They are a common size. Just be sure to get completely sealed bearings.
Take the arbor to some place that has a bearing press and have them remove the old bearings and press on the new bearings. You will have to remove some clips to get the old bearings out. You can pound the old bearings off if you want, but it is easier with a press. Install the new bearings, being careful not to nick them when you put them back in. Do your pressing on the inner bearing races, not on the outer race. Reinstall the the clips and reinstall the arbor assembly.
While you have the arbor assembly out, do yourself a favor and replace the pulley with a new cast iron pulley. You can get it at the same bearing house for a few dollars - They aren't expensive. Cast iron pulleys are well machined, so it will help your saw run smoother. Be sure to use a drop of Locktite on the pulley set screw. It is hard to get to the set screw once the arbor is back in place.
Reassemble everything, align the pulleys, reinstall the belt (now is a good time to install a link belt too - you will be glad you did).
The whole process only takes a couple of hours if you have to take the arbor to a store to press the bearings.
Robby Wright
San Marcos, Ca
Re: arbor bearings
>I don't have anything to add, I just liked seeing "Barry is correct" in print. You can bet I will be sending a copy of this to my EX Wife. And another one to my kids. I'm going to print it out too, just to have written proof that it happened once. What a great end to the old year and start of the new one.
One more time Barry Is Right. Has a nice ring, don't you think? Everybody... BARRY IS RIGHT!.
Too bad it happened so early in the year, it's all down hill from here. I've peaked.
