200+ woodworking book reviews
Squaring Cabinet problem
Howard
>I am building cabinets that are 26" deep and 27' tall. Sides are 3/4" ply. The problem that I am experiencing is that the carcasses are square in the back when I put the 1/2" ply backs on , but when checking the diagonals in the front, they are out of square by 1/8" to 1/4". These will be frameless cabinets. Is this to be expected with cabinets of this depth, or should I do something now to get them squared before installing them, they are base built-in cabinets going into a space with walls on both sides. Appreciate your help.
Re: Squaring Cabinet problem
David Yoho
>If this is after the fact, I don't have any suggestions for a frameless carcass. If you still have more to make or haven't glued the carcasses yet, you could clamp some square blocks of solid wood or plywood in the front corners during your assembly. These will help square the front and the plywood back will take care of the rear.
(SEE DRAWING BELOW) Make up some pieces cut about 5 - 6 inches square (square being the key word here and at least two legs if not all four square). Take a forstner bit and drill two holes large enough for one jaw of a "C" clamp or similar type. Then clamp them to the four front inside corners until the glue sets. These should keep the opening square.
David
Lee Schierer - McKean, PA
>Wow 27 foot high cabinets....Where did you find plywood that long. :)
You should be able to get closer to square on the front. Can you shim one side or the other to raise up that corner a bit? If your wall isn't flat or perpendicular to the floor it will tend to rack your cabinet. Without reinforcement in the front at the corners, I would expect they might vary about that much on the diagonal.
Lee
Jim Dillon
>Howard,
Is it possible that the pieces of plywood are not exactly "square" to begin with? When building our kitchen cabinets (which you are basically doing), I found that it is more difficult than I thought it would be to get pieces cut that were exactly "square". I finally constructed a large sled for my table saw and that was a tremendous help. Another thought is whether or not you are getting the plywood side edges to fit together well during glueup. If the edges will not show, a brad nailer would help hold them together until the glue sets up. IIRC, I glued the four sides together first, then added the back (again cut perfectly square), and stapled (I was using 1/4 inch ply) one edge, lined up the other edge and stapled that, then the remaining two edges and then let the glue dry. Again, IIRC, I got diagonals closer than a 1/16th. Just some rambling thoughts.
All this assumes you are not really buiding a 27 foot tall cabinet 8-). If you are, then you should congratulate yourself and go have a pre-New Years beer!
Jim
>A 26" deep frameless cabinet will have a lot of give at the front. I would try to make sure they are square when you glue and screw or biscuit or whatever you are doing, but you should not have any problems installing them square if the plywood sides are cut square. A lot of people assume that plywood sheets are square. So long as the two sides are the same length at the front and the top and bottom are the same width you should be able to install them with doors so that everything lines up.
Carol - now in NC Nebraska
>"the two sides are the same length at the front and the top and bottom are the same width"
Sorry, Moses, but doesn't this also describe a parallelogram?
The last cabinets I have done I did with pre-banded Melamine 25", or 15", or 12" wide stock from the borg (even can get it pre-bored for shelf pins). That took care of the same width issue.
It quickly became apparent that I was responsible for making the "square" cross cut to length. Easier said than done. Too long to use the tablesaw. Too wide for the SCMS. Left me with a couple of choices. Rough cut to length and re-cut on the table saw with the sliding table. Don't like doing things twice.
I settled on using a circle saw and a really careful guide system. Checked and double checked for square before cutting. That went well.
Next problem. Getting the pieces exactly the same length. If the sides are different length, no chance of a square cabinet box. Ditto for the top and bottom. I used a pair of long straight edge (metal yardsticks work well) with stair stops on it. I used that to set the saw guide. Sort of a variation of the stop sets on the SCMS extensions. Simply clamp them in place on the end, Clamp the saw guide against the end of the straight edges. Double check for square before removing the straight edges, and you're good to go.
'Twas a little fussy at first, but then when I stacked the parts and ran my fingers around the edges to find them exactly the same size - YES!
Anyway that's how I get square boxes. The 'rule' I taught in class was mirror images for sides and mirror images for tops and bottoms and 90� corners on all make for a square box.
Warren E. White
>Jim, do you have a picture (or drawing) of that monster sled? I just finished an entertainment center for my daughter and had exactly the same problem. I felt like a sled was the fix, but don't know exactly how to go about building it.
Warren
Jim Dillon
>Warren,
I don't have a digital pic of the actual sled I used as it was constructed during my pre-digital camera days and I am away from my shop right now. However, I found a pic of its twin, a smaller version maybe 18 inches wide. IIRC, the plan came from FWW, but there are many plans available. The bottom (on all three sleds I've made) is 1/2 inch baltic birch ply. The fences are from 3/4 inch baltic birch ply. The rear blade guard is from 1/2 inch ply. The slots you see are for plexiglass blade covers (which I seldom use). I would guess the width of the largest sled that I used for the kitchen cabinets is maybe an inch wider than the cabinet width (maybe 27 inches??). The width is at least as wide as the TS, maybe 10 inches more. It is a handful, so I wouldn't want to make it any wider. I would be happy to get the exact dimensions and a digital pic for you in a few days, and I might be able to find the original FWW reference. Thanks for your interest and I hope this helps. I wish I had a better pic. IMHO, a TS sled (of whatever size) is an incredibly useful addition that also makes it safer to use the TS. Have a Happy New Year!
Jim
Pic #2
Jim Dillon
>I think the deep box will have some flexibility to it. If you build a parallelogram almost square, it can be made perfectly square when it's installed. If you build something that is not a parallelogram and is not square, it never will be square. Your process of making a box square is great, but if you put it together and set it on the bench and push on the front top right hand corner it will no longer be square. This of course is referring to frameless cabinets and is not so much of an issue with framed cabinets. When installing cabinets they cannot just be screwed to the wall bam bam and you're done. Soemthing that most installers really don't comprehend.
Howard
>Thanks all for the great responses. I'll use this advice on the next ones I build.
