Unisaw Belt question
Dustmaker Mike
>I have a 3hp unisaw. It has the standard 3 belts on it. I took the motor off to make it lighter to move it. When I put the motor back on the two outside belts seemed loose. Not by a lot but the center belt is tighter the the outside two. I checked the motor mount and the blade arbor and they seem fine. So is this a problem I should fix before I run it? Should I buy three belts just to be sure? I don't have 220 to it yet to see if works like it is. I wanted to make sure before I turned it on.
