Stupid TS blade Question?
>I have a Forrest WWII blade on my TS and really like it. Had it for 3 or 4 years. I have used it for everything as a hobbiest. The question is, how do I tell when its dull? I know that's stupid, but it doesn't seem to cut quite as easily as it did before. Pieces seem to want to ride up. This is subtle and I am not sure whether I am jaded or the blade is dull. Anyone sent one back to Forrest? What did it cost and how long did it take? Were you happy with it? Good and new?
Re: Stupid TS blade Question?
advice from manufacturer
Bill Tindall, E.TN
>The local place that makes blades told me that the most obvious indication of dullness can be seen in a cross cut. If there is splintering on the exit then the blade has dulled. On the other hand, if it still cuts to your satisfaction and this splintering is of no consequence to your sawing then it is sharp enough.
A 10X quality hand lens is a handy aid to assess sharpness of woodworking tools in general. I keep track of their sharpness by examining the edge from time to time with the lens. At 10X magnification it is easy to see the progress of dulling of chisels, saw blades, etc. On a saw blade look at the top of the tooth and watch the progression of rounding on the leading top edge of the tooth.
In spite of the hype that is associated with Forest blades, any competent shop can sharpen them. Meisenheimer told me they sharpen hundreds each year.
Should have bought a smart table saw blade!
Dan Manturi
David Yoho
>Barry, as Bill indicated, you'll notice dullness more when cross cutting - especially the bottom of veneered plywood. I recently sent mine back to Forrest for sharpening and when I put it back on the saw I immediately noticed a difference - not only in the way it cut but the way it sounded. Mine sees constant use in all types of material and hadn't been sharpened since buying it in 1998. Sure cuts nice now and the cost and wait is minimal.
David
Re: advice from manufacturer
Gary Evans Tallassee, TN
>Hey Bill,
Do you have contact info for Meisenheimer? I have a bunch of 10" blades that I've collected over the years that could stand to be sharpened.
Thanks,
Gary
Doug Boor
>I send my sharps to get tuned up after a few projects, probably more than I need too, but everytime a blade or bit comes back, they work better and leave a smoother finish. Very good investment, particularly with a Forrest blade. On a side note, I got a tour through Forrests manufacturing facility in NJ. Very impressive, looks of eyes looking at every blade through every process. Looking for any runout, or anything out of true. A great company with a great product. PS, I don't work for them, just a woodworker.
Dale Lenz
Dale Lenz
>> Pieces seem to want to ride up <
Like you said when you need to push stock harder into the blade, an unsafe practice, as you are well aware of, is a very good indication of a dull carbide blade. When I start to burn cherry on rip cuts more than normal, another indicator.
Back in Sept. my Freud 42 tooth C. blade needed sharpening, but had to made a healthy run of flag cases. As I started working my stock rode up a few times, told myself, to be more careful than normal this run. Just got the blade back, and have not sawed anything yet, but should be a very welcome improvement.
Larry Clinton At Frankfort (Central)., Indiana
>Barry: Before I determine I need a blade sharpened, I first clean the blade and remove ALL the gum burned sap etc. from the blade. This often restores it to good working condition. The indications of a dull blade (and/or dirty one) are: 1) Splintering during crosscutting - especially on plywood & veneer. 2) Pressure required to feed the material through the blade - this increases as the blade dulls & 3 tooth marks on the cut surface - this shows up especially on rip cuts in cherry, maple etc. and last #4 excess "burn" marks - especially on cherry - although a real dull blade will also burn oak and other woods. I used a local sharpening service for my WW 2 - He does have new computer controlled sharpening equipment. I intended to send it to Forrest - cost was about the same including shipping taxes etc., but I needed it faster. He did a good job, can't tell it from new.
Jim Dillon
>Barry,
I sent my WWII back to Forrest for resharpening. I think it was around $20 or so. IIRC it came back within a week. My shop is in northern Virginia and Forrest is in NJ I believe. I would use them again in a heartbeat.
Jim
