Re: Wood Dye Question follow-up
>The directions on the can of RONAN refined lampblack say that the paste should be thinned with turpentine to be brushed on and top coated when dry. I think a couple days would be enough time for it to dry, but might expect some lifting even then. The alternative would be to mix it directlly into the final finish, whether a drying oil or film finish.
If you use an aniline dye stain, like Transtint, I suggest the water soluble version for its ease of use and color fastness. Mix it with about a quart of water and mop it on the pre-dampened wood. Wipe it back to even out the tone. After it's dry, and rubbed down with a maroon scotchbrite to get rid of the fuzz, it can be top coated with any non-water based product without lifting.
For your application, I think the RONAN approach will give a more even and deeper black than the dye stain which may reveal the grain.
Clint
