Miter saw dust collecting
Bill P
>Does anyone know a way to hook a Delta 12" miter saw up to a dust collector? The hose for the miter saw needs to be 1 3/4" ID. I have been looking and can not find a hose that size. What does everybody else use?
Bill
Re: Miter saw dust collecting
>I built a "shield" that stands behind the miter saw - think of a "V" shape. I put a small 4" flanged piece on it near the back and I hook my 4" hose which leads to my DC system - it doesn't work great, but it works reasonably well. It also easy to do :).
George@Colonel's Workshop
>Good Evening Bill,
I use a 4" DC system and made reducers to step down the diameter of the hose to the port on my SCMS. It is marginally effective. I think rigging a large DC scoop behind the slider would be more effective if space were available in my small shop. As it is, I have to pull the saw cabinet away from the wall so I can use/swing the slider. I do manage to get by with the present system being enhanced by a Shop Vac.
George
Jesse Cloud
>I cough, I sneeze, I blow my nose a lot, and take lots of showers.
If we can send a man to the moon, how come nobody makes a CMS with dust control. I suspect if we stopped buying the crap they are foisting on us, we would get good dust control real fast.
And yeah, I have tried shrouds and v shields and all kinds of stuff. I have my CMS connected to a 2 HP oneida inside a shroud, but its still disgusting how poorly it collects dust.
>I have my ancient Delta chop saw sitting on a shelf that is also a shroud. In the rear bottom is a 2 X 10 slot hooked to a four inch pipe from my DC. I usually have a piece of hose from the blade guard hanging loosely into the slot. (Dumbo's nose) It was fairly easy and works fairly well.
Re: Picture, picture...
>just so long as you don't have Dumbo's ears! :).
>Here it is, its just a box that has a back and a bottom and sort of cut away sides and top. It looks like it is sitting on the cabinet below, but it is not, it hangs from the wall. The cabinet can roll out form under it. There is a shaper to the left and a Radial Arm Saw to the right. The box for the Chop Saw is set up so that the table is at the same height as the other two and all three fences are aligned. So I can slide long pieces pass them and they don't get in each other's way (much). The little piece of blue tubing you can see is the Dumbo Nose. The blast gate for this is to the right. As you can see, I have a small cluttered shop. Behind the chop saw are piles of glue blocks nestled in the places that the chop saw doesn't need.
bobnald
>I agree that I have not seen any really effective way to do it.
I bought a very large storage container and mounted it to the back of my cms on its side. I mounted the hose from my dust collector to the bottom (would have been the side of the container in its intended use). The whole thing is mounted to my cms cabinet with a French cleat so I can remove it quickly and easily. I also ran a small hose from the exhaust spout to the d/c opening and secured it with a couple of plastic ties.
Tough Job
>Bill,
The CMS and SCMS saws are, perhaps, the most difficult to control dust. Their dust collection ports (and bags) are largely ceremonial because the dust is coming off those blades at high speed and a low angle. I tried several direct connections to my DC but they were a waste of time. Even tried a 2-hose setup with a bugle port fitting tucked in behind the blade. NG
I then went to a "drop box" design that uses a hood and space behind the saw to let the dust slow down and then drop into a funnel that had a 4" port in the bottom. That concept was about 75% effective, but didn't do much for the fine dust that would still bounce back out of the enclosure.
I finally went with my current setup shown in the pic; a full cabinet with drop-down extension wings and lots of storage under. The hood is made of 1/4" ply that was then fiber-glassed over the outside with polyester resin and light weight cloth. The hood has six 2" ports built in that vent into a plenum below the saw platform that also pulls from a main slot at the bottom of the funnel-shaped drop. What you don't see in this older pic is the air "curtain" which, composed of 3" wide 8 mil vizqueen strips, hangs from the whole front edge of the hood. With the rig hooked into the DC on a 6" draw, it is 99.99% effective, even on compound angle cuts. I can live with that.
