Re: DVD recorder help?
JohnKJordan in East TN
>Is this a standalone recorder? If it's anything like the the Panasonic and Pioneer models I have and have had, making simple DVD's is incredibly easy once you set the right mode. It was so simple and quick to record that even when I needed to produce an authored DVD with custom menus, etc, I would often dump the video source directly to the recorder, rip it from that DVD with software, then author and burn a new DVD.
Recording from video tape (or any video source) to DVD is simply a matter of making the audio and video connections, setting the right mode on the recorder, pushing Play on the VCR and Record on the recorder. The recorder does the encoding according to the mode you've set - the recorders I'm familiar with allow several different quality modes, the tradeoff being the recording time. After recording, you can add optional text titles, etc, and you have to Finalize the disk so it can be used in other players.
If there are specific things in the manual you don't understand, maybe you can describe them here for interpretation. If you started reading the manual and gave up, try again and read all the way through. You should be able to ask for advice at the store where you got the recorder. If you bought it on-line, any 15 year old kid should be able to help!
