Picks what sizeis 80kb
Wayne
>I can resize my picks but my program doesn't give me the choice of kb for sizing. How about pixels or ??
Re: Picks what sizeis 80kb
Try this
>I don't know what program you're using to process your photos, but the final file size is dependent on both the number of pixels and the amount of JPG compression. Somewhere in your program you probably have a choice of pixel size, and somewhere else you have the ability to choose "quality." In a typical imaging program, this quality dimension is expressed as a compression percentage. The higher the compression, the lower the visual quality but the smaller the file size. We have found that you can get some pretty remarkable quality out of a relatively low compression ratio, as shown in my old standby picture below, which was first reduced to its current size and then saved at a fairly low compression (probably 25% -- I can't recall exactly). If your program doesn't allow you to dial in the ratio, see if it offers you the option of saving the image as "e-mail friendly," or medium quality or something other than huge.
If you have the time or inclination, there are some articles in our FAQ area that may shed additional light on this. It is a fervent hope of mine that we will figure out how to allow people with fast connections the ability to upload large photos and have them automatically reduced by our software. It is on our list of stuff to incorporate in any future messageboard renovations.
Ellis Walentine, Host
A point of reference
Dan Donaldson
>If I take a picture that is around 1600 pixels wide and about 900K or so, resize it to 600 wide, and save at around 75% compression, I get a picture that is usually around 40-60K. I usually play with the compression to get it below 40 k in deference to those with slower connections. The 600 width is a fairly good size to give detail without making people scroll around to see the whole picture.
Re: A point of reference
JohnKJordan in East TN
>If you have Photoshop, there is a "Save for Web" option on the File menu that lets you pick the desired file size and it picks the exact quality setting needed. It will let you compare the original and new image side by side for a quality evaluation.
Re: Suggestion from an expert - trial and error.
Peter Gregory
>None of us know this answer either, at first. What we do is setup a temporary directory, and then start to save things into it. Go check the results as you go, upload the one you think is right. Once it works, write yourself a post-it, so when you forget you don't have to do it again.
Let's face it, computers stink for getting simple answers. You have to expend a little effort and look at the results.
Re: Picks what sizeis 80kb *LINK*
Jim Dillon
>Wayne,
There are dozens of image resizing programs available, but few offer the option of setting the compressed file size prior to resizing. Here is one that does (if you are using Windows) and the price is right - its freeware. For WoodCentral posting, I set the long side of the image to 550 pixels and the file size to 38K. This setting usually gives me a file size of less than 40K. You can also adjust other things like sharpening etc. and preview the resized/sharpened image before committing yourself. It will do batching of files as well.
Another free resizing utility that is very user friendly (IMHO) is PIXresizer avaiable at http://bluefive.pair.com/pixresizer.htm. While it does not allow setting the file size (at least in my version), you can adjust the quality setting to get what you want. I like this program because of the friendly GUI and the default file-saving nomenclature. It is Windows as well. Hope this helps.
Full disclosure here: I actually use PhotoShop CS2 as John suggested, but that is because photography is another hobby of mine so I have it available. If I didn't, I would use (and have) the programs mentioned above.
Jim
BDSizer
shrink pic
lee beeden
>Google 'Shrink pic' its a free download...once you have installed it you can set the compression levels and then every time you send a picture( e- mail or woodcentral) it automatically compresses the photo for you. I installed the program about 6 months ago and have never done anything since, it just runs in the background.Its great!!
Lee
Jim, smaller is kinder but if you find that 40K degrades a particular image too much, a bit earlier Ellis changed the minimum on this forum to 80K. JKJ
Thanks John...
Jim Dillon
>... for the reminder. As I was typing the 40K limit, somewhere in the back of my mind was a past post by Ellis announcing that the limit had been moved to 80K but I wasn't certain. As you said, while 40K can work (sometimes surprisingly well) 80K is better. Thanks again for the clarification.
Jim
