round inside round inset
Bob Sobieck
>I would like to build round end tables, using two types of wood. One, darker for the outer rim, the inner circle of lighter wood. Any idea how to ensure that the inner piece fit snuggly so that when finished does not show a gap of irregularity?
I am thinking of cutting the inner with the router at this point.
Bob
Re: round inside round inset
Dick Coers
>Bob,
I've done that by using a 1/4" bit and a 1" guide bushing for the hole, and the 1/4" bit with a 1/2" guide bushing for the insert. I make the pattern using the router with a trammel. It's the same idea as the inlay kits that you can buy, but that kit only uses the 1/8" bit with a really short cutting length. Be aware of wood movement if you intend to use solid wood. A solid wood insert will probably blow up a solid wood rim when the insert expands this summer. That insert would be a great place to use some really nice veneer.
On the rim I only use the 1/4" bit to make the sizing cut. I follow that up with a rabbeting bit to finish machining the lip on the rim.
