Threading a brass rod Question.
>Being a wood worker I only occasionally use taps and dies. Now my son wants to thread a brass rod. It's 3/16". Does anyone know if a No. 10 die will work for that. I have both coarse and fine No. 10 in a REALLY CHEAP CHINESE set I bought at HF for just such an occasion. (Always good to set a bad example for the kids and buy crummy tools. That will teach them.)
What does the No."10" stand for anyway? And what should I use to thread it?
Re: Threading a brass rod Question.
As I recall from my hardware store days…
Rod Peterson -- Ormond Beach
>…#10 and 3⁄16" are the same diameter. 24 TPI for NC and 32 TPI for NF or SAE. It seems to me that 3⁄16" was normally associated with stove bolts, which were always NC. I can't remember seeing the stove bolt description in a  l o n g  time.
Remember, it's been nearly 50 years, though…
Rod
Larry Clinton At Frankfort (Central)., Indiana
>Yes Barry it should work ok. The fine die is #10 -32 threads per inch, the course should be #10 - 24 threads per inch. The 3/16" rod is .187" in diameter - A #10 screw has a major diameter (after threading of about .181 to .190 (depending on class of thread - this is only important in machine work). So yeah, go ahead and thread it, I would use a tapping lubricant - If you don't have any Kerosene or even WD 40 will work.
Glenn Madsen near San Francisco
>I can't relate to the taps and dies - I never yet learned to use them. But cheap tools are a tradition in parts of my family. I have a brother-in-law who loves to shop at the discount table of the local Ace for made-in-China cheap stuff. He's so frugal it hurts to watch!
The cheaper tools in my shop are to loan to my sons, who aren't always the best at returning certain items. They, for example, are precluded from using Lie Nielsen anything except under direct supervision. Lee Valley the same. Marples, though, ...
I'll have to have my dad show me how to use those cheap Chinese taps and dies soon, I guess. I'd like that, while he's still healthy and able.
Happy Holidays!
Paul Waddle
>As has been stated,yeah,go ahead and thread the brass rod with a number 10. Unless necessary,I would stay with the NC thread. The problem you will run into,if there's any length involved is crooked or off center threads. To prevent this,you need a 'deep' die to keep the rod centered. Attach die to a chuck or block of wood/metal that will snuggly fit the 3/16th rod and this will keep it aligned while threading. Just ask me how I know(how about a new acronym "JAMHIK". PW
Thanks and.....
>We both tried threading the 3/16 with the No. 10 die and could not make it work. It just chewed the end off the rod. He switched to No. 12 and it worked fine, but then he decided that 1/8" rod would look better and he bought some of that and threaded it with a No.6 die. Worked fine. Thanks for the help.
Re: Thanks and.....
JohnKJordan in East TN
>I didn't thing of mentioning this earlier, but a local craft shop sells a variety of threaded brass rods in case you need this again in the future.
Re: Thanks and.....
>I know I have seen it somewhere, but can't remember. I actually thought Lowes had it in 1' lengths. My son did not think to look in the short lengths.
We just threaded some more for him. We had an Epiphany. He said' "the hard part is getting started", "I almost wish I had not cut it up, I could have just thread the whole thing". So we chucked the longest piece he had left in a drill and drove it through the tap in less than a minute. At the end, we removed the drill and finished it by hand. Then we did the rest of them in four inch pieces. He was right, getting it started took longer than doing the rest, but driving it with a drill was a great thing.
