Braders vs. Pinner
Tom Norton-Chardon, Ohio
>So how do you use them and in what applications?
Trying to determine whether to get a pinner.
Braders vs. Pinner
Re: Braders vs. Pinner
George@Colonel's Workshop
>Good Afternoon Tom,
Pins are virtually unseeable after the finish and top coats are applied. They are used when you need to keep a piece of molding or face frame in place "while the glue dries", or until you can get the clamps in place. They are great for applied molding in cabinet furniture, such as to retain mirrors and glass. If you don't want to see the mechanical fastener, use pins. If you need something more robust, use brads.
George
Glenn Madsen near San Francisco
>All I can add to the good knowledge the Colonel offered is that, when you take a thin fastener, and make it longer, it loses stiffness as it penetrates the wood.
A 2" 15 ga brad is stiff, whereas a 2" 18 ga is flaky, and goes where it wants, sometimes with bandage consequences for the unwary. 18 ga at 1 1/4" seem fine, though.
Pins are 21 or 24 ga, IIRC. I haven't spent the cash yet, so I don't have any. But 3/4" is about the most I'd trust them, and I'd use them to hold until an adhesive of some sort cures up.
I also vaguely recall something about a head on brads and finish nails, and probably not on the thinner pins. That would make a difference in holding power, and entry hole size, as well.
David Yoho
>18-gauge brads are good for many cabinetry projects. They have a rectangular-shaped head that is visible when used and should be filled. 23-gauge pins being smaller and headless, almost disappear when used but don't have the holding power of the larger gauge brads. They are great for tacking on molding or holding two glued pieces until dry.
My pinner will shoot a 1 3/4" pin into solid oak just fine. The thing to remember is pins are more light duty than brads.
