Big time saver for scroll saw work
David G. Sparks
>I recently discovered something that is going to save me loads of time. I was talking to a guy at a craft who cuts ornaments using a laser. I cut ornaments with an Eclipse scroll saw. The laser guy asked if I wet my wood to raise the grain before sanding it. I told him "No." He said that even though he uses a laser for cutting, wetting the wood before sanding makes a major difference in how clean the cutting turns out. The other day, I dampened the Baltic birch slightly to raise the grain. I used a heat gun to dry the plywood before I sanded it using 220 grit paper on a pad sander. After I finished cutting out the ornaments using reverse tooth blades I discovered that all the fuzzies were eliminated! I have previously spent hundreds of hours with a tiny file cleaning up ornaments, so this technique is a major breakthrough. I haven't tried this with wood cut with spiral blades, but I feel sure it will help.
Re: Big time saver for scroll saw work
Ron Hildreth
>Great information there, David. Lots of little things pay off in the end, like using packaging tape to prevent blade burn. There's just enough lubrication in the tape that prevents it!
Ron in Iowa
Terry Quiram
>David
Don't you just love the Eclipse? I owned 2 Hegners prior to buying mine. When I am scrolling I will make a couple of cuts then flip the piece and sand the fuzzies. When I am done there is very little clean up. For the final sanding I use a hand held sander with the piece laying of a piece of carpet padding. As long as you don't apply downward pressure with the sander your cut pieces will clean up very nicely.
Terry
