ADVERTISE HERE - FREE TRIAL
Wood Treatment....
Wood Treatment....
Wood Treatment....
john l. blue
>I just cut down 20 small longleaf pine trees, after cuttin' them up into 12 ft. lengths and debarking them, appreciate advice on how
long to let them dry-out afore treatin' them.
Realize they ain't cedar, but, just want to see how they'll do after
coatin' them with some wood underground preservative. Blue
Re: Wood Treatment....
Keith Newton------WebKitFormBoundaryDZmgloT+ZiYFgX
>I don't know how fast this time of year, but the pine will dry fast enough for pressure treating in a month or less in Summer. I had 1000 bf pressure treated for ground contact, for around $100 last Summer.
But if you are experiencing cold weather, and thicker material, it will take longer. The wetter the material, the less treatment it will take in.
Re: Wood Treatment.... *LINK*
JohnKJordan in East TN
>The Wood Handbook lists longleaf pine as "moderately difficult" to treat by penetration. Are you brushing or soaking? One of my fence books (Fences for Pasture and Garden) indicates that treating fence posts yourself is largely a waste of time and money since the perservative will rarely penetrate completely and the post will rot from the center. They list one possible exception: treating freshly harvested, debarked posts in a solution of borate sulfate (Tim-Bor), claiming that if the moisture content is at least 40% the post will pick up borates from the surface and diffuse them by osmosis to the center. This infusion should be followed by butt-dipping in copper naphthenate, soaking overnight.
Do you have a pressure treatment facility nearby? (I know of two near here) A small operator may be willing to throw your posts in with a batch. The posts should be as dry as possible first.
I'm not familiar with longleaf pine, but if you stand some logs up on end, some water will literally run out the bottom. However, due to the way relatively humidty works, wood dries very slowly in cool or cold weather. Even in the summer, air drying logs is far different than air drying lumber - you didn't indicate the diameter but it may take years for the center to dry.
There are experts available. You might check the knowledge base and/or ask your question on this site:
Wood Web sawing & Drying forum
DizD
>For ground contact, pressure treating is the only sure way to get long term protection. Soaking w/ a preservative will only create a "shell" of treated wood - might buy you a few years, but you would need to figure cost/benefit ratio. Prior to pressure preservatives, treatment was done by burning ends of posts to create a layer of charcoal around the end to go in the ground. Soaking ends in used motor oil was also used.
Borates offer another alternative and it works best on green wood. Do a Google search for a product called Jecta. You would have to look at costs of treated posts vs cost of chemicals to treat them yourself.
one other product
DizD
>You can also look up "Impel rods" and "Cobra rods" - these are borates which are inserted into drilled holes to provide a sustained release of borates.
Borates are good but they are water soluable and there is presently no way to "fix" them in wood.
Re: one other product
john l. blue
>I appreciate the replies, I'm checking up on everything y'all said.
thanks, what a great site! Blue
Dale Lenz
Dale Lenz
>All SYP accept pressure treatment very well, better than most other softwoods. The heartwood of SYP does not accept treatment very well. This is why the Garden Timbers/landscape timbers fail.
Borate seems to be a good treatment in the proper place. Borate in wood where it is exposed to high moisture, such as the ground, causes the borates to leach out.
As another poster stated all other "dip treatment" is superficial, may buy some extra time.
The price quoted above for pressure treatment stated above sounds like a winner to me.
I worked with a forest landowner several years ago and he traded X peeled pine post for getting Y pressure-treated post back. Maybe something to consider.
Good luck
