Another option, *LINK*
Keith Newton------WebKitFormBoundaryDZmgloT+ZiYFgX
>If I were needing to work in a small space, I would rather have one of these, than a small 6" stationary model. I have had one since about 1980, and it still does a great job for my job-site jointer, and around the shop when I have big 8/4 lumber and larger that gets too big for me to handle on my 12" jointer.
I have some special jaws that hold it in a slide action vice for small work. But when I get big beams, I either clamp the wood in the vice, or lay it on the bench top, then run the tool over the work. You can change the depth of cut on the fly, so working a hump down is easy.
I use it a lot around the shop even with the big equipment right there. I could not say the same for those other options. My 2�
http://www.toolking.com/makita_1806brr.aspx
