Unisaw pricing
Unisaw pricing
Unisaw pricing
Dan Arrowsmith
>Would a unisaw from the 1970 with a 3hp single phase with unifence be a good buy at $650. Its local so I can pick it up but wondered if it is too old for such a price.
Thanks for your advice and opinions
Dan
Re: Unisaw pricing
yes
Thomas S Stockton
>That's a good price if it doesn't need any parts or major work. Don't worry about paint that's a cheap fix if it bothers you. There's not much that goes wrong with them. If it runs and stops without any vibration the bearings are usually good. If it's sat a while (like a year) the belts can get a flat spot which is more of a thumping sound and a cheap fix(get your belts at a local bearing place way cheaper than delta and just as good). one other thing to sheck for is if the raising mechanism works all the way up the end of the casting for this piece can snap off kinda rare but it happens.
I would jump on it if it is decent shape there fairly industractable and the uni fence is a very workable design.
Tom
Re: Unisaw pricing
Absolutely
Roger Lance in GR, Michigan
>as long as everything checks out, thats a very good...approaching gloat status...price.
Re: Unisaw pricing
Re: Absolutely
Keith Newton------WebKitFormBoundaryDZmgloT+ZiYFgX
>You should drop whatever you are doing and buy it as soon as you can get to it, or it will be gone to someone more deserving for not having wasted the time which you already have.
Go now, or be sorry you didn't.
Re: Unisaw pricing
Yup, if not in need of costly work.
Gil Jones on Lake Seminole GA
>I bought mine in 1986 (3hp w/unifence), and it still has the same belts on it. "Zero" problems.
Gil
