fireplace mantle
fireplace mantle
fireplace mantle
Brian A
>I am looking to put up a 6X6 pine post as my fireplace mantle. My wife wants an old barn beam look. I was thinking about distressing it (to get rid of my frustrations) by banging it around and using the edge of nails etc to mark it up with maybe a little black in some of the dents but unsure how to get the color to look like old beat up wood. Any ideas?
Thanks
Brian
Re: fireplace mantle
knotscott
>Distress it, stain the deepest marks with a dark stain, then sand the whole thing to remove the stain from the undistressed surface, leaving the deepest marks dark, then finish it uniformly in whatever color and finish you're looking for.
Weather It
>When you get done beatin' on it, fire up your compressor, take that $12 Harbor Freight sand blaster you bought with a bag of #2 sand, set things up well away from the car or house, put on gloves and a full face shield, and let'er rip. In very little time you'll have this wonderful weathered beam which you can then tint with dye stains, some paint spots, and other and assorted evidences of age and neglect.
But wait! You don't have a compressor or a blast gun?
Dude, why are you sitting here reading this? You are now in
PRIME TIME TOOL ACQUISITION MODE!!!!!!
LOYL has asked for a part of her home to be made a certain way, so get out there and DO IT and get the tools you need to complete the task.
mm
This guy is good!
Eddie Pacheco; San Jose, Ca.
When It Comes To Buying Tools
>I can't be beat at the justification game!!
"But Honey, that's what you SAID you wanted . . ."
>I happened to get the latest issue of FWW at the newstand yesterday because it has a spice cabinet in it. It happened to have a small article about charring the wood with a propane torch then going over it with a wire brush. This removes the softer spring growth rings and leaves the harder summer growth rings. It's definitely something I will try at some point (on a peice of scrap first). I would stain the pine a light color then put one coat of finish (sealer) on it then glaze it with dark glaze beofre top coating. This gives a rustic look but not really weathered. Remember if you are doing worm holes they look natural if you have a number of worm holes in isolated areas scattered along the board and not just random single holes scattered all over.
JohnKJordan in East TN
>The local woodcraft owner said hand-hewn beams are popular for mantles - flat on the top and hand hewn on the front. I've tried that with a log using an axe with moderate success. I bought a nice broad axe at a yard sale but haven't put a handle on it yet - I understand from the books that's a broad axe is an easier way to go. (I looked for a good broad axe head for a long time before I found one that hadn't been ruined by grinding a bevel on the flat side.)
A broken piece of concrete
Keith Newton------WebKitFormBoundaryDZmgloT+ZiYFgX
>makes a good distressing tool, because it has a good assortment of sizes and shaped points to strike / roll/ scrape with, and one a little larger than a brick has enough heft to do the job.
Bill Hammond, Oregon Coast
>It you want the weathered look as opposed to the hand hewed look there is nothing faster more fun or as effective as fire! The propane torch is the tool of choice as mentioned above. Work the torch and wire brush together. Think in terms of just where the beam was when it was weathering and work the heavy 'rot' in the appropriate places. You may want to leave the top alone and do a nice furniture finish on it so that it looks like you took a weathered beam and plained the top down and finished it and left the rest of it alone. If you leave some charred wood in the deep holes and then use an oil Cape Cod Grey stain doing a rub on rub off it will look rather realistic. You can shape it first too, should one end have a tendon on it, or perhaps a mortise with a peg hole, a big old cut nail driven in and left there? You could even paint something there like a horse name, as in over a horse stall, then when distressed and weathered there would just be a ghost of it left.
Bill, who believes that if you found a simple way to do it you haven't tried hard enough.
I forgot to mention.....
>Have a pail of water and rag handy to control the burn.
An acid wash does some strange/nice tings too, mercuric acid that is used to clean masonry can be used.
good luck, Bill
muriatic acid?
mdclor
