OT Computer Noisy Question
>I have a HP Pavillion 7965 about 7 years old. A few moths ago it made loud noises and I took it to the shop. They charged my $100 to tell me the screws were loose of missing for the power supply. (They are the only people that ever worked on it and I thought it was outrageous to charge me to tell me they installed the screws they left out last time.
It is now making noises again. Sounds like a small electric motor that is struggling. I opened the cabinet and blew it out. There are two fans, one of the CPU and one in the back that is bigger. Its better, but still noisy. Any suggestions?
Re: OT Computer Noisy Question
Bill Hammond, Oregon Coast
>Unplug first one fan and then the other to see which is making the noise. There is another fan in the power supply (most likely) What ever fan is noisy replace it. If it is the PS fan replace the PS. you can clean the fans but they do not last long after the noise starts. If the fan on the CPU is the noisy one you can remove the fan and heatsink from the CPU and clean all the dust and grime out of the fan and the heat sink. You should still replace the fan but it might work until you get the new one in. Bare in m ind that without the cooling fan on the CPU the CPU has a life of about 60 seconds.
When replacing don't just buy the least expensive. You may wish to go for one that is quieter. The PS and fans are simple to replace (far easier than laying on a good finish) and are available on the net at fair prices.
If you blow out the fan and PS be careful to not spin the fans too fast with the compressed air or vac.
Bill, way over here where this years total rainfall in now in excess of 65 inches. 11.5 this month. Sure glad it's not smow
Ray, SW Ohio
>you may have 3 fans, mine has a fan in the front to pull air into the case. i build my own and the case came with it. the fan on one of my video cards was going out and it made a whining noise.
Bill Howatt
>Unless you have some experience, I would not remove the fan and heatsink from the CPU. The surface should be cleaned and a very, very small amount of heat-transfer compound properly applied before the heatsink is reinstalled. Some are easy to replace others can be a PITA.
Bill
Thanks, I fixed it I think.......
>Went to the local computer store and bought a fan from the resident Geeks. Actually Son of Geek.
I checked out the fans before I went thanks to advice from here. Turns out there were four fans. Power supply, a fan for the case with a big scoop on it, a CPU fan and one of the video card. It was the video card fan that was failing or at least whining and sounding like it was failing. The new fan had a three wire plug on it and the old one only had a two wire plug. The Geek said there would be other plugs for it on the mother board. Not that I could find. So I went to Radio Shack and they had no such fan. I asked about a splitter to use one plug for two fans, but they had none. Went back tot he local guys and they had no other fan or the splitter either, so I plugged the fan in with the two matching wires only and it works.
The fan came with a sticky back on it so rather than Plug and Play, it was peel and stick. Just cleaned the top of the chip and stuck the heat sink on it. So, I am quietly back in business.
The irony of the situation is that my son installed this video card several years ago. Recently, I found and threw away the original video card. Very unlike me. My pack rat gene is screaming "I told You so!". Had I not over ruled the gene, I could have just plugged the old card back in. It was ever thus.
So, Thanks for the help and we will wait and see if this holds up.
Re: There was a reason the old card was replaced
Glenn Madsen near San Francisco
>Video cards are one of the places where 'old' shows up first. When replaced, the system is often happier. Software gets updated with new drivers. Things look better.
You DON'T want to go backwards with computers. It's not at all like hand tools for woodworking.
Third wire
Bill Howatt
>The third wire was the speed sensor wire and obviously not used on the card. If your other fans have 3 wires the system can monitor the rotation speed. There may be a program (such as ASUS Probe for ASUS motherboards) that came with your motherboard to let you monitor the temperatures, voltages and fan RPM while in Windows. Sometimes you can see them in BIOS as well but that isn't real useful.
Bill
dump it in the trash and get an IMAC !!!!
Mark Valsi
