Bookcase design input part II
Ken Krawford
>A prior post requesting ideas resulted in suggestions of a Palladian design for the top of the bookcases (Thanks Tommy and Ellis). I made a scaled drawing and encountered 2 other issues.
First - what to do with the area above the bookcases (green diagonal lines area)? Leave it open?
Second - The top of the cases is below the bottom of the half round window. I was unable to find an arc radius that would clear the sloping ceiling and still intersect the bottom of the half round window. Do you think it looks ok as is or is there a solution I haven't considered?
Thanks again for your input.
Re: Bookcase design input part II
Mike Hamilton
>How about moving the outer arches in one column on each side and leaving the outer columns flat-topped? Or maybe cascading arches (losing a little space - but it'd look pretty art-deco)?
Just imagining,
Mike Hamilton
Plainfield, IN
Eddie Pacheco; San Jose, Ca.
>Hi,
On your first question, I would leave that area as free space and then it can be used to hang two or more small pictures. Seasonal wall treatments would work there too.
Regarding finding a suitable arc. Try laying this out with Sketch-up and then you can come with something that will line up which may come out to some oddball value, but you can make a template to make it work out.
Here are two quick schemes I came up with using a 10' ceiling and an 8' x 4' window and then going out 24"/shelf column.
Good luck with this, it looks like a neat project.
Ken Krawford
>Eddie,
I love your design! Thanks for taking the time to make the sketch. I'm the type of person that understands things so much better if I can see them.
David Hay @ Denver
>Another idea that comes to mind regarding #2, what if you used a 1/4 oval (ellipse) instead of a 1/4 circle for the outer cabinets. The oval could extend from the wall to the bottom of the semi-circle.
David
JohnKJordan in East TN
>Ken,
Do you have curved tops on the end bookcases or is the top open? (Is the arc shown just the back of the cabinet?) If the tops are closed and the green diagonal area is left open above the cabinets, it may be an issue keeping the tops of the rounded areas clean.
Also, is the entire central area the window, extending to the floor? From your previous sketch I thought the bottom of the window was considerably off the floor:
Do you have dimensions of the room and window (including the proposed cabinet depth)? If so, I might make a simple 3D model for you.
Ken Krawford
>The tops of the bookcases are closed so keeping them dusted would be a concern. The window is about 18" off the floor. The new scan chopped it off.
What about the other dimensions? (window width and height, room width and height, wall height, cabnet depth) With these I can very quickly make a 3D model so you can visualize your design. (That is, if you think it would be helpful. I do than when designing many things I build.)
