glue bottle for biscuits and white glue
les winter
>I'm starting construction of kitchen cabinets. 3/4" ply with hardwood face frames. I'm using biscuits and screws to hold the sides to the top and bottom. Full screwed and glued 3/4" back.
I've seen these specialty glue bottles, costing from a $5 special extension nose to an $80 Lamello. Are any of these usefull?
I'll be using white elmer's glue unless someone has a better idea.
Thanks and regards
Les
Re: glue bottle for biscuits and white glue
Ed Wozniak, Buffalo, NY
>I have done a bit of plywood construction with biscuits and pocket screws. I never used a special applicator for applying glue. I just squeeze a little bit of glue into the biscuit slot and apply some glue along the mating surfaces that I spread out with a stick. Norm seems to always use some special glue applicator for biscuits, however.
I think people normally use yellow glue for woodworking applications. I think the strength of white glue is probably adequate but yellow glue may have a more appropriate drying time for typical wood projects.
Jim Dillon
>Les,
I've never used anything special either. I squirt a bit of glue into the biscuit slot from the regular glue bottle (experience will guide you on how much to use) and then squish it around with a solder brush which is thin enough to get into the slot. I buy my solder brushes from Lee Valley (IIRC) and they are cheap. Hope this helps.
Jim
>I use yellow glue for all this type stuff.
I have a cheap biscuit applicator glue bottle and have used it on larger projects. Mine does not meter out the correct amount of glue, you just squeeze it. On smaller projects, I never bother with it, I just do as others mentioned, either just squirting in a little glue or use a solder brush. The applicator stops up if you don't clean the tip after you finish and it's a PITA to clean once the glue dries. So, if you get one, be prepared to clean it after you use it while the glue is still wet.
I also wonder if the glue in the slots is really necessary. I mostly use biscuits to align pieces and don't really rely on them for holding power. So on that type of glue-up, I don't pay much attention to thoroughly coating the slots. If a little gets in there its OK, but if not, that's OK too.
Carol - now in NC Nebraska
>The biscuits are compressed. The moisture from the glue causes them to swell, really locking in the joint. That's why it is important to store them in an air-tight container. They can and will swell thicker than the slot you cut for them if you don't. VOE*
voice of experience :)
Bill Spievak
>I have used the Lamello one time, my neighbor has it. I will tell you it makes the job easier, but I have nevr been able to justify the cost. I only used it the one time because he saw me using biscuits and offered; I've never felt the need to go ask him to use it again because I don't think it is worthe the cost and I don't want to bother him.
Jesse Cloud
>My favorite glue bottle is a ketchup dispenser from the dollar store. Nice pointy tip to get into small places, cute cap on a plastic ring so it doesn't get lost. Best of all 2 for a dollar.
Larry Clinton At Frankfort (Central)., Indiana
>I bought one of the glue bottle kits (I think I'm a sucker for most gadgets), from either Rockler or Woodcraft. I did use it about 3 or 4 times. Then I bought a couple of ketchup bottles for a buck apiece. That is what I use 99% of the time. The kit stopped up easily, was time consuming to clean up. Just not worth the hassle. I use acid brushes (I trim the ends off the bristles so their about 1/2" long) and also the wider "disposable" natural bristle brushes - trimmed the same way. I purchase the disposable brushes for around $10 for 30 and usually buy the acid brushes at big lots or flea markets in bulk.
>Carol is right, the biscuits do swell. This is one reason you can not use them in really thin stock. They swell and bulge the surface and have been known to "photograph through" and become visible in the finish. So when I use them strictly for assignment, such as edge to edge long grain joints, I may not wet them, on purpose.
Hmmm! Maybe what I should do is make some biscuits out of the same stock I am gluing. Then there would be no issues with swelling. ????
>As I understand it, a normal cause of the telegraphing of the biscuit is premature sanding after glue-up. The moisture in the glue causes the wood to expand (worse in thin sections), if this is not allowed to shrink prior to sanding, excess wood is removed from the "swelled" area over the biscuit. As the wood drys and shrinks to it's original thickness, a low spot develops leaving the outline of the biscuit below the surface.
