Dog house roof question...
David Sparks
>I've been working on a house for my dog Charley. It will be in a dog kennel with a tarp over it, so it won't be directly exposed to the elements. I'm planning on using a piece of white plexiglas to cover the plywood roof instead of using shingles. The plywood is primed and painted. Here's my question: Should I install the plexiglas right on the painted plywood, or should I put down roofing paper or something else between the plywood and the plexiglas? I'm concerned that moisture will build up under the plexiglas and cause mildew. I will appreciate any ideas. Thanks!
Re: Dog house roof question...
>You could take a tip from the guys that install metal roofing.
They put felt (tarpaper) down first and then they put down stringers of 1" x 4" parallel to the eaves. They put them at about 3' intervals and along the edge. You may not need the felt with the primed plywood. But if you put stringers of 1" x 2", this would avoid the condensation problem and might help with keeping it cooler in the summer and warmer in the winter. Just a thought.
David Sparks
>Thanks, Scott. That's a good idea.
Johanna
>I built a big doghouse that is thoroughly insulated. The roof is two layers of 1/2" plywood with foam insulation sandwiched between the layers. That is topped with metal corrugated roofing. I made the roof in two halves for easy removal so I can clean out the doghouse from time to time.
For ultimate whippet comfort, there is a dog heating pad (metal) the wire to which is housed in a corner so it cannot be chewed. All four of the dogs will fit, but usually the whippet establishes ownership and won't let anyone else in. The others, all of whom have better fur insulation, make do with two other plastic doghouses.
