1/2" or 3/4" plywood?
wilbur
>I want to put a stud frame up against one of the walls of my basement shop, and then attach plywood to the stud frame, with the thought of hanging tool racks and cabinets off of the plywood. Would 1/2" plywood be strong enough for this purpose, or should I use 3/4" plywood?
Re: 1/2" or 3/4" plywood?
Bob in NE Ohio
>Wilbur
I did mine about 3 years ago and went with the 3/4. I have hung several cabinets on the walls with no ill effects. I don't know how 1/2 would work but For the difference in price over the long haul I'd go with the 3/4
Bob
Re: 1/2" or 3/4" plywood? - How close are
Ray Carson, Lawrenceville NJ
>the studs? Is the stud wall freestanding, attached to a block wall, supported by the floor and ceiling? What kind of weight are / is the plyood supporting? Are you hanging machinery, shelving, wood storage? I'm just asking to get a feel as to what your use will be. :-)
I would think about screwing the "ply" to the studs also.
Ray
steve - Denver
>I used 1/2" for this and it has worked fine.
>I paneled my 34x40 shop with 1/2" A/C ply, and painted it a barely-off-white. It works great for hanging shelves, brackets, etc., and the light color reflects lots of light. It also adds strength to the stick framed walls.
Clint
steve - Denver
>I'm assuming you'd screw any cabinets into the studs.....
JohnKJordan in East TN
>>...with the thought of hanging tool racks and
Instead of hanging from the plywood, consider hanging heavy things from the framing lumber, just as you would do if the wall covering was sheet rock. If you know ahead of time where the cabinets are going, you can even add extra horizontal 2x blocking between the studs before putting up the plywood. In this case, the thickness of the plywood doesn't matter much. (I used much less expensive 3/8" plywood in my feed/tack room and it is holding up wonderfully.)
I plan on covering my shop walls with plywood as well - I want to plan it around permanent workbenches and such and install with screws so I can easily remove panels as needed to access wiring, etc.
Clarifications
wilbur
>Just to clarify, here are some things I should have put in my original post.
I'm going to attach the studs, spaced a standard 16" apart, directly to a cinder block wall, using Tapcon screws or something similar for the most part. There are some areas on my ceiling that I could attach a header 2x4 to, but only in some spots due to wires, pipes, and other things that I want to have access to. I can support the studs on the floor end. I don't envision supporting machinery, lumber, or anything heavy on this particular wall -- I plan to mainly be mounting racks and small cabinets for hand tools.
I'm not sure as to the exact location of said racks and cabinets, though, since my shop set up process is still in flux, so I was hoping to mount the racks directly to the plywood to aid in moving them in the future, if needed. I suppose I can mount the cabinets directly to the studs, even if I move them in the future.
The price difference between 1/2" and 3/4" plywood isn't a factor -- I am just keeping in mind that I'll be mounting the plywood by myself, and I'd like to avoid wrestling a 4' x 8' sheet of plywood solo. A man's got to know his limitations. :@) But if 3/4" is the way to go, I'll figure it out.
Re: Clarifications
>I have 1/2" plywood on the side of a saw cabinet that I run screws into to hang stuff on and it is a bit on the thin side to do that. You would have a lot more fun with the 3/4" ply, perhaps get a friend to help you hang it.
Re: Clarifications
Paul Waddle
>Just my .02. If you are going to mt directly to plywood and ignore framing,go with 3/4. Its way overkill if you do use the framing. If you are going to use a nail gun,mounting shuld be relatively easy,but no getting around that heavy handling. Hope you have a good way to use a skill saw(festool etc). If it were my shope,I would get a nice grade,one side sos I cold varnish it. pw
Agree on 3/4" ply - Surfaced one side
>I would have to echo Paul's thoughts on the ply having one good side. I would also agree with Moses on the 3/4 ply and getting creative and having more flexibility.
I finished a portion of our basement for our kids playroom and used 2x4's at 16" o.c. Of course, I used gyp board but the studs were anchored with tapcon screws and L brackets.
The kids have an air hockey table that took up some floor space so I came up with an idea. I took the legs off and mounted the table portion on hinges and attached it to the studs. They can swing the table up and out of the way when they aren't using it. Had I used "ply" I wouldn't have had to plan on stud layout.
Just think of the possibilities of having swing away tables and work stations mounted to 3/4" ply. Also, plan ahead and consider some built-in type features. This also would save floor space.
My $.02 worth,
Ray
Re: Clarifications
Bob Entwisle in NJ
>wilbur,
I agree that 3/4" ply is the way to go. email me if you need hand wrestling it onto the wall.
Bob in NJ
