Porter-Cable 690 routers - how's quality?
>Are the P-C 690 routers holding their quality? Rockler's got them on sale for $100, and I'm considering whether I want one.
Re: Porter-Cable 690 routers - how's quality?
Rob Sandow
>They are bullet proof, but also technological dinosaurs. I prefer a router with a switch on the handle, soft start, electronic variable speed, micro-adjust mechanism, and other modern features. My 690 only gets use with a D-handle base on the Leigh jig.
Rob
Try Amazon (through WC, of course)
Rod Peterson -- Ormond Beach
>Add a P-C690LR to your shopping cart (be sure that Amazon is the seller, not one of the other two or three Amazon associates). Then add a P-C 343 ROS to your shopping cart (also using Amazon as the seller). Proceed to checkout and when you get the page where you select your payment method, type FREE343K (make sure you use the caps) in the coupon box. At the final check page you should find a ≈$59 credit (meaning the sander is free), and you should be able to check free shipping, too. They are on back order, so you won't get it right away, but two pretty nifty tools in the New Year for a C-note isn't bad at all.
Rod
I have a couple
Tim Greif - West of Chicago
>I got my first one as part of the kit with plunge base. I added a D-handle base and got a bare base for mounting in a table. I picked up another Lever Release 690 for $99 at HD a couple years ago. I'd say it's well worth it, and if you can still get Rod's deal, that's even better.
George@Colonel's Workshop
>Good Afternoon Bill,
I also have two P+C 690s, together with all associated bases. Great tool. Design improvements could make it better, I will agree. Some variants do have a soft start and slightly more power. But, I couldn't be happier with mine and won't ever need to replace them, I'm sure. One does most of the router table work. I got my second one for $75 from Craigs list. It was nearly unused. Together, they are great for tails and pins. Bullet proof is a good description. My oldest is around 10 years old, and it is USED nearly every day, with no discernable runout. I love the collet design. Never a problem with bit release.
George
Re: Try Amazon (through WC, of course)
Terry Alexander
>Rod,
I just tried this and it says the coupon FREE343K is not valid ;-(
Also...you say to make sure the seller is Amazon. I never left the Amazon page, but it says the seller is Timberline tools. I am kind of new at this, so...any advice?
Terry Alexander
“Any advice?” Yes…
>When you're on the P-C 690LR page (for example) you should be able to Add to Cart (on the right of the page) with any of two or three vendors. Amazon will clearly be labeled Amazon—other sellers might be Timberline (as you noted), Dardansupply, or Viking Mountain Tool Works. Those last three are Amazon associates, not Amazon itself. They aren't involved in the free sander promotion. That's why you need to make sure you've selected Amazon and not one of their associates.
Good luck. I ordered mine last night. It's been going on for about a week. It's been even cheaper—somewhere around $88, I think.
Rod
Binen
>THANKS! I was looking for another ROS sander. Didn't really need another router but with the combo deal I couldn't pass it up.
Binen
Re: �Any advice?� Yes�
Terry Alexander
>You just gotta know what you're doing.
Thanks for the info. I just ordered and it went just like you outlined. $59.00 credit (ROS is free), free shipping.
AND....since it came from Amazon, then Woodcentral benefits also.
Ah.....2 Christmas presents for 2008 off the list.
Terry Alexander
