Watco vs BLO, and why each has its place
Michael Dresdner
>First, let's clarify. Watco Danish Oil is not oil. It is a varnish modified to make it easy to apply by flooding on and wiping off. One reason it dries faster than most BLO applications is that a large part of it is resin, not oil.
For that matter, how fast boiled linseed oil (BLO) dries depends largely on two things; how much drier has been added to it, and how much access it has to oxygen. Thinner coats mean more oxygen, as does higher drier rates, since the function of the drier is to shuttle oxygen into the oil.
Various manufacturers put both different amounts and different types of driers into their BLO, so you really can't make blanket statements about its drying time. For the uninitiated, BLO is simply raw linseed oil with driers added.
Using oil to pop the grain works for two reasons. Thanks to its low molecular weight, oil will go deep into wood, causing the upper layers to become more translucent as they become saturated. Thanks to its color, it will tint the more absorbant areas more than those less absorbant, thus intensifying subtle grain, such as in figured maple.
Other low molecular weight materials, like shellac and Danish oil, do the same thing, but with slightly different visual results. Try a sample of all three and see which looks best to you.
One note: any solvent based coating will go over dried linseed oil or Danish oil nicely, but if you plan to coat it with a waterbased coating, use a barrier coat of Zinsser SealCoat first. It's not necessary with all brands of waterbased coating, but it is with some, and it is not worth the risk if you don't know for sure.
