I've Had Both
Marvin Horn
>I put a Home Shop Biesemeyer on an old Craftsman's contractor saw several years ago and it made a world of difference in how I worked. Literally quit using a pocket tape on most setups. Absolutely top notch. Got a used cabinet saw 4 years ago and put the Grizzly fence on it. Works great, but have never trusted it like I did the Bios. Can't tell you why, but I don't.
The major differences are in the fence facing. Biesemeyer uses Baltic birch faced with laminate- Grizzly uses UHMW. Both work fine but the Biesemeyer id definitely "flatter". I've never seen this to be an issue except when aligning the fence to the "T" slots. The Biesemeyer also has a machined surface on the top of the rail while the Grizzly is unfinished and painted. I feel like this made the Biesemeyer a little smoother to move but couldn't prove it. The Grizzly is more robust, in fact material specs for the classic are almost identical to to the Biesemeyer commercial version. The plastic tape that came with the Grizzly was a piece of crap- bought a tape from Biesemeyer to replace it.
Bottom line- both are fine fences, and with regular cleaning and waxing will do everything you need. I like the Biesemeyer better but not enough for me to pay the price difference at retail. If you find a deal that's another issue. Good luck!
