Need help ASAP:Jointer
Todd
>I'm stuck. I'm trting to glues up some pamels but I can not get the joint of the 2 boards to be tight (the cut on the table saw does better than the jointer.....). The knives are set to the same heigth as the out feed table. I am keeping pressure on the outfeed side to hold the board to the table. The infeed and out feed tables are approximately 33" long and the boards that I'm jointing are 72 inches long. The jointer is putting a bow in the middle of the boards (i.e. when the 2 boards are put together and touching in the middle, there is a gap on each end). I can make this gap bigger by removing more material on the jointer (deeper cut). I have taken a striaght edge, placed it on the outfeed table and measured a .020" difference in the infeed table (.000" at the blade then going to .020" at the start of the table). I do not know if this causes the problem but if so, I do not know how to adjust the infeed table to make it parrel to the outfeed.
I tried moving the outfeed table higher with respect to the blade. When feeding the board through, I would get half way through and then the jointwe ws not cuttng the board any more (actually raised the infeed side of the board off the table
I need to fix this issue ASAP so any ideas on what to check and measure would be great........
I have the Delta 37-380 8" professional jointer (not the DJ-20 8").
