REAL MILK PAINT
OT-Running Boards For Tundra
Howard
>Need to put on running boards on my Tundra 2007 crewcab. Any recommendations for the right brand and any pitfalls in doing it myself?? Thanks for reading
Re: OT-Running Boards For Tundra
no suggestions
Bruce, a MN Galoot
>but please post what you pick and why. I'm considering them for my Tundra, too.
Bruce, in snowy MN.
Re: no suggestions
Basil
>I can't speak directly as to your Tundra but for Ford and Chevy, it's easy. Well, easy for the "pipe" type steps. Just unscrew the cap hanger bolts (long bolts with rubber bushing and large body washer). Then there is a piece of angle iron that goes under the body washer (below the rubber) and hangs down a ways (leave cab bolt a little loose so you can wiggle and adjust the angle iron after mounting the step). The pipe step then bolts to the angle iron (there is a right and left step on fords and chevy's, probably the same for yours). Tighten the step bolts and then finish adjusting angle iron and tighten the cab bolts, you're done.
Took me and 12 year old son less than 30 minutes to put them on my last extended cab Chevy.
If you go with the diamond check, aluminum running boards, it going to take longer. That's been an all day job for me on a couple of Duallys I owned.
Re: Thoughts on mine
Brian in Brighton
>I have a 2000 F150 and so does a buddy. I got the factory plastic ones that have a flush wall on the inside of them. Not the pipe style. He has the pipe style. Here is where the problem comes in and I don't know if it applies to you. If you get snow YOUR tires will push it from under your truck onto the running boards and make them very messy. Mine has a wall inside, so the only snow I get comes from other cars around me. Might seem that it is not a big deal, but it is a huge difference in the amount of snow on the boards.
Brian in Brighton
Possible answer here.
Eddie Pacheco; San Jose, Ca.
>http://www.tundrasolutions.com/forums/tundra/119414-so-many-nerf-bars-running-boards/
Re: OT-Running Boards For Tundra *LINK*
Tates in Chesterfield, VA
>I have a Tacoma and ask most of my questions to Toyota Nation web site. The Tundra is at:
http://www.toyotanation.com/forum/forumdisplay.php
