Delta 13" bandsaw - have to hand start
Terry Alexander
>I have the Delta 13" bandsaw. When I hit the "start" switch....it hums and will trip the breaker if I do now open up the top cabinet and "help" start the saw by giving the upper pulley a good spin. It then starts and continues and works very well. This is more of a minor inconvenience right now because I only use my bandsaw maybe once or twice a month. However, I am going to start on 2008 Christmas presents now and I will be using my bandsaw a lot.
So...having said/typed all of that, do you know what I need to do to correct this?
As always...thanks in advance.
Terry Alexander
Re: Delta 13" bandsaw - have to hand start
Bruce, a MN Galoot
>I'd check the starting capacitor on the motor. Take it off and bring it to an electric motor shop. BTDT, easy fix.
Bruce
Terry Alexander
>I hate to be "dumb"...but are you saying to take the entire motor to an electric shop or take off the starter capacitor and just take it in. If it is just the starter capacitor, can you tell me where it is located and what it looks like ;-)
TIA
Terry
Rick in Colgate, Wi
>Could be that the motor has an accumulation of sawdust inside and may need a good cleaning especially if the motor has brushes.
Rick
Bruce, a MN Galoot
>Blow out the motor, as Rick suggests. If that doesn't work, the starting capacitor is the "lump" sitting on top (usually) and is held in place by two screws. There are three or four wires inside, usually just joined by twist connectors, at least mine are. Note how the wires are connected and take it all apart. If you're not comfortable doing that, just take the whole motor in.
Dan Donaldson
>There is a start switch in the end of the motor that has a set of contacts that close when the motor is stopped and open after it starts. A lost of the time, open motors will get sawdust in the contacts and you will get exactly the symptoms that you are describing. Try blowing the motor out with compressed air and see if that helps. If not, and you are comfortable doing it, you can take the end off the motor and clean the contacts. It is not difficult if you are at all mechanically inclined, just watch how you take it apart and watch out for the springs on the weights. If you don't want to try that and blowing it out doesn't help, then you would need to remove the motor and take it to a repair shop.
WARNING !!!
Ken Oakley-Sunny St. Cloud, Fla.
>Start capacitors will retain a charge even after the motor has been turned off. If you touch the terminals you could get knocked on your Tutty as the charge grounds thru your body.
You have hurt this 14" saw's feelings by calling
Art Silva
>it a 13".
