Re: sniping on jointer
Grant in Iowa
>Wayne,
Unplug the machine and check your setup:
-Take a steel ruler or similar object (you can use a straight board, just make a mark on it so you always start from exactly the same point). Stand it on its edge and place it on the outfeed table such that the 2" mark precisely aligns with the edge of the outfeed table adjacent to the cutterhead. Rotate the cutterhead by hand in the normal direction. The knife should pick up the ruler and move it between 1/8" and 1/4" as it goes by top dead center. Check each knife at each end and they should all move the ruler or board about the same amount...within a 16th of an inch or so.
-If this test is causing your ruler to move more than 1/4", RAISE your outfeed table. If the test causes your ruler to not move at all, then lower your outfeed table to bring the amount it moves to about 1/8". This 1/8" usually means your outfeed table is about .002" lower than your knives, which I find to be about right. Note that if the readings vary widely, then you need to adjust the knives individually. Indeed, this method is what I use to align the knives when I change them out at sharpening time. Fast, works good, and no need to buy fancy jigs.
If you are having a gap form beneath your workpiece during a cut, then I think the first thing to check is the outfeed table height. If you are having trailing edge snipe on your workpiece, then raise your outfeed table and make test passes to tweak its height until you get no snipe.
Also look closely at the "planer" marks on your workpiece after a pass. They should be evenly spaced, and if they aren't, your knives need adjusted.
Another possibility is technique. As you feed work into the jointer, you must not apply too much downforce to the piece while it is on the infeed table, and certainly not enough to bend the workpiece. Once the work makes it to the outfeed table, make sure it is held on the surface of the outfeed table. You can use plenty of downforce once the work is on the outfeed table (assuming you aren't working with a badly warped piece, needing additional passes).
You can also check the coplanarity (is that a word?) of the infeed and outfeed tables by laying a long straightedge accross the top of the jointer and raise the infeed table to very close to the straightedge. You can then tell either by eye or with a feeler guage how far out of planar the two tables are. Check your owners manual for adjustments, or call Grizzlys tech support line.
Hope this helps!
regards,
Grant in Iowa
