OT: HP PhotoSmart 3210 "Ink System failure"?
Dominic Greco in Richboro PA
>Hi everyone,
Please forgive the OT nature of this post. Even thought this is a woodworking forum, I've found that we have such a diverse community here that I can post questions like this one. I'm hoping that if I don't get an answer, that someone here can point me in the direction of where I can get one.
I have a HP Photosmart 3210 All in One Printer that is just under a year old. It was installed on my wife's computer and was working quite nicely until 2 weeks ago when it started giving her some grief right after she ran out of ink. I believe that part of the problem was she was turning it off incorrectly (these USB printers like to have the computer turned off before they are). I purchased HP refills and replaced the empty ones. It was at that time I first noticed this error message coming up on the printers screen:
Ink System has failed. Unable to print, fax, or copy. Refer to printer doc. Error: 0xc18a0501
Since I could not get it to work promptly, I gave her my old printer to use and installed the HP Photosmart on my computer.
The troubleshooting section of the printer documentation had nothing on this error (Typical). When I went to HP's web site and Searched on the phrase "Ink System Failure", I found a small troubleshooting doc about this error.
I was told to:
- Press the On button to turn the printer off
- Unplug the power cord from the back of the printer
- Remove all the ink cartridges
- Wait two minutes
- Plug the power cord into the back of the printer
- Press the On button to turn the printer on
- Install the ink cartridges when prompted
If the error code does not display, the issue is resolved.
I did this THREE TIMES!! I still get the same error message.
Has anyone had this happen to them? I'm hoping there is a work around, or something I can do that will not require me to get this printer serviced. I bought it off of Amazon.com for under $200 and have a bad feeling that servicing it will cost just about as much.
Thanks in advance.
Dominic
