Log question for all you lumberjacks and jills *LINK*
Brian in Brighton
>Here is a set of logs that I saw on E-Bay while doing anything but working.
My question is simple. Do you see how the sap wood on the end of one of the medium logs is so different in thickness from one side of the log to the other? What would cause this?
Brian in Brighton
Walnut logs in Iowa
Re: Log question for all you lumberjacks and jills *LINK*
Gary Evans Tallassee, TN
>Hi Brian,
I would guess that the log in question was probably leaning some. That is the usual reason when the pith is off center.
Gary
Dale Lenz
Re: Actually....
Dale Lenz
>two of the logs have non-equal, off centered sapwood. Notice that two of the logs have a sweep in them, probably from bending toward the sun. Some of the wood in those two logs will have reaction wood, compression or tension wood, can't recall which is which, one occurs in softwoods and the other in hardwoods. Causes fuzzy wood, funny drying, etc.
Merry Christmas
Re: Actually....
JohnKJordan in East TN
>>reaction wood... Causes fuzzy wood, funny drying, etc.
What's worse, reaction wood can cause severe warping, not only during drying but sometimes sawing releases internal stresses can even warp and crack the boards right on the sawmill.
The smaller logs appear to be limbs of the larger log. I would not buy these with the intention of getting good lumber out of the limbs. (Limbs are great for firewood.) However, some of the crotch wood might provide fantastic turning stock.
BTW, the photo below is from a dead limb which I had to remove from an oak tree here. Notice the similarity to the offset pith in the heart wood on the third and fourth closeup pictures in the ebay link.
This limb was nearly horizontal for at least 40 feet from the tree which explains the extreme reaction wood. The oak tree is about 3' in diameter - I counted nearly 100 growth rings in this limb!
Re: Looks like one tree? Yard tree?
Peter Gregory
>When I look at the pictures, it looks like the big part is the main trunk, going up to a "Y" and the little pieces were above that. As others have pointed out, the stuff above the Y is not good for woodworking (I'm guessing).
I wanted to add that the main trunk might be a yard tree and if it is, might have metal in it. No one likes to make lumber out of trees with metal, it wrecks the blade.
Have fun.
