Have a question? Ask Woody!
Heat-resistant glue
Heat-resistant glue
Heat-resistant glue
Phil Berman, Montvville NJ
>Happy holidays all -
I'm building a fireplace surround and am concerned about heat softening the glue holding this together. The pieces that span the firebox will be subject to some heat, and as they're rather chunky pieces, are very heavy. I'm relying on the pieces on either side to support this piece. Fastening it to the front, thru the marble, is going to be impossible to do without having the fasteners visible, not to mention that the piece bows out approx. 3" at the center. In order to accomodate the bow, I'll be joining 3 pieces of 8/4 walnut, mitered at the appropriate angles, end-to-end and then carving the bow out. Glue-blocks will be used on the backside, as these joints are endgrain-to-endgrain. Not sure yet about mechanical fasteners due to the carving, but I'll probably be able to accomodate for some screws. I'm concerned about the glue softening under the heat and allowing the pieces to shift, if not totally come apart. Does anyone have any thoughts they might share on how to overcome this problem?
Thanks,
Phil
Re: Heat-resistant glue
Paul Woolson
>I've found polyurethane glues to be the most heat resistant. Epoxy will creep at 140 degrees, tightbond at about 160. You can find heat resistant epoxies at specialty industrial supply stores but you'll pay for them for sure.
Give gorilla glue a shot.
Pat Riley in SLC
>Standard silicon glue or RTV is good to 450 degrees F.
It will work great, but will stay flexible even when cured.
In some spots it might work, but hard to tell without the design.
Pat
The Fireplace Guys
>Around here all use 100% clear silicone. After one of them told me "how to", that's what I bedded my insert with and it's just fine so long as it's not in a location to be "touched" by the flames.
mm
Re: The Fireplace Guys
>Thanks, Mark, but I'm not installing an insert, just building a fancy mantel. Silicone isn't going to hold wood-to-wood, and certainly not in a stiff-enough fashion to hold the mantel in one piece. Imagine a 3-sided bay window. That's what is going to span the front of the fireplace. From that 3-sided piece, I'm going to carve what will ultimately appear to be a bow shape with some molding, some carving, etc. It's this 3-piece subassembly that I'm concerned with. The fireplace itself is traditional masonry construction, so the mass really throws off a lot of heat after a fire's been cooking for a while.
Phil
Bruce, a MN Galoot
>Seeing as how one of the methods of disassembling a PVA joint is to use heat, don't use Titebond.
I guess you're going to have to experiment, but I'd start with a slow setting epoxy or plastic resin. Maybe Urac 185. When I was still making archery bows, I cured the epoxy at about 200F. I looked at the Weldwood plastic resin specs, but it didn't say anything about a max temp, just a minimum working temp. But that stuff holds so hard that if I were in your shoes, I'd start with the plastic resin.
Bruce, who says Merry Christmas and good luck!
Gary Evans Tallassee, TN
>Hi Phil,
Back when I used to work on Pontiac Fieros and Transports, the two-part adhesives that they used to bond plastic body panels onto metal subframes required about 400 degrees to soften enough to work the panels loose.
Unfortunately, I don't know what kind of adhesives those were. Might check with a body shop?
Gary
