Arm-R-Seal and Bri-wax
Pete
>I've got two coats of Arm-R Seal on a Hickory endtable I'm building... Is it Ok to wax over the finish with Bri-Wax?
Pete
Absolutely
Mike Schwing from Maryland
>It is absolutely OK to do so. However, wait for it to cure before waxing over it. A couple of weeks is fine. BTW, 3 coats looks a lot nicer than 2 coats.
Re: Absolutely
Pete
>Thanks. Problem is, it's a Christmas present...... from Christmas 2006. I never got it done so I swore to give it this year. Anyway, I'm putting the second coat on now and will give it to my dad tomorrow. I gues I'll have to drive down in a few weeks and wax it real good for him! Maybe he'll let me take it home and put on a third coat. Merry Christmas,
Pete
Hold off
David Yoho
>You absolutely MUST wait for any film finish to cure before using Briwax over it. If you don't, the solvent they use will mess up your finish. Only use Briwax over cured finishes. A paste wax like Johnson's is better if you're in a hurry but you still need to give it some time (about 2 - 3 days) before applying.
David
Re: Hold off
Howard Acheson
>You are correct in your advise. Briwax Original uses toluene as its solvent. Toluene is much more aggressive than the mineral spirits used in most other paste waxes and may easily affect oil based and waterborne finishes that are not completely cured. Briwax is intended for the restoration trade so the aggressive solvent allows it to better clean old finishes. Many recommend not using it on a finish less than a year old.
Briwax has a standard paste wax called Briwax 2000. It uses mineral spirits for a solvent and is perfectly safe to use on newly cured oil based finishes
Re: Arm-R-Seal and Bri-wax
Paul Cates - Henderson, KY
>I don't know what Arm-R-Seal is composed of, but I used Bri-wax on a lacquered cherry table and it ruined the finish. I didn't test an inconspicuous area first like you're supposed to, and I had no idea I needed to wait a year as someone else mentioned.
Howard Acheson
Arm R Seal is a thinned polyurethane varnish.
Pete
>Thanks for all the construtctive comments. I ended up putting only two coats on and it matched dad's existing furniture exactly. He's going to wait a week or so and use paste wax on it.
It's my first piece ever so I'll get around to posting a picture eventually and asking for critiques. Thanks again
