Died poly on brush
Died poly on brush
Died poly on brush
Joe in a Cleveland suburb
>Hello.
I have a somewhat decent brush that I allowed poly to completely dry (cure) on. I totally forgot about it. Is it doomed? Anything it can be soaked in?
I searched the archive because it seems to me I've seen this a time or two, no luck.
Suggestions? Toss it?
Happy Holidays
Joe
Re: Died poly on brush
>Joe, there's very little that "Quick-eze" brush cleaner won't take out. Thing is that the chemicals needed to really clean the brush may cost more than the brush.
Worth a try, but not too much of one.
mm
George@Colonel's Workshop-Havertown, PA
>Good Afternoon Joe,
Before you toss it, try a methyl chloride chemical stripper, or a solvent sold in hardware stores and labeled for that purpose of saving paint brushes. Truth be told, I generally wind up tossing most hardened brushes, as they are fairly low price/quality to begin with. Only scary sharp bores me more than cleaning brushes.
George
Howard Acheson
>I have "saved" brushes frequently using a pretty standard "Brush and Roller" cleaner that you can get at any home center or paint store. Just let it soak and follow the directions on the label.
Get a paper route!
albertabob
>Tt's acost of doing business. Some you save, and some your don't.
The govt(AKA save the planet with beaurcatic solutions) has pushed the prices of any rememdy beyond what the replacement cost is.
What's that about?
bob
It's Most Likely About
>Less [per brush] impact on our air and water to make a new brush than it is to use the toxic and residual chemicals needed to clean an old one.
What it has to do with a paper route, however, I haven't a clue. I had one of those (140 daily and 110 sunday - Arizona Republic), and can honestly say that while I had trouble with a bush or two, no brushes were involved.
mm
Re: It's Most Likely About
albertabob
>Mark I would hate to leave you hung up on the intended humor.
Quite simply put we are trained pretty well not to beleive that it a gigajuole of energy is expended in China complete with the carbon release that is obviously less harmful to the environment than restoring a brush with a bit of solvent or Dic adoo.
By the time the brush reaches Kansas it has passed over land and sea and then land agian to be ultimately tossed in the landfill.
My reference to the paper route was to point out that most people with a finite income may find themsleves doing without certain things as our Chinese neighbours begin to tightnen the noose around consumer products.
For many of you that will start this year.
Merry X-mas
Bob
Jason Roehl in Lafayette, IN
Don't forget...
>...to factor in the cost of your time when you consider reviving that brush. If it just has an outer crust, it may or may not be worth cleaning (again, cost of solvents, and the time involved). If it's hardened through and through, don't bother. You might get it clean, but it will never really be the same, and you can get pretty darn good brushes for under $20.
As a painter, I wish I could say I've been perfectly disciplined in cleaning all my brushes immediately after use, but the reality is that I've probably spent in the thousands of dollars on brushes. The upside is that I usually have newer brushes on hand to use...
Jason
