Miters on a band saw?
Basil Biberdorf
>I'm building a candlestand that requires a "box" on top (four 5.5" wide boards, joined at the corners, which will hold sand when attached to the carcass below it). I'd like to miter and biscuit the corners, but I'm finding this difficult without a table saw. (No room for one.)
I'm having problems getting this done on the band saw, so perhaps this is the wrong approach.
Is there a way to do this on the band saw, or do I need to look at another method?
Sorry to be such a newbie for what should be a very straightforward task it would seem.
Re: Miters on a band saw?
Ed Mulligan, Cape Cod
>You could cut close to the line with your bandsaw and then finish to the line with a router guided by a straightedge. To get equal lengths on your four pieces you would have to construct a jig of some sort.
Another way to finish would be to use a hand plane. The stock would be held in a miter shooting board or (if you are forming a bevel) a donkey's ear.
Ed
Two Questions
David Yoho
>Does your bandsaw have a miter guage and does the table tilt? If so, tighten the blade, set the table, slide in the miter guage and test on some scrap. Should work well enough.
David
Re: Two Questions
Basil Biberdorf
>Table tilts, and miter gauge is present.
Works ALMOST well enough. Problem is getting the line super straight. The leading
edge of the board (first end into the blade) isn't quite straight, probably due to blade wander/leading.
Things got better when I moved to a 3/4' 4tpi (or so) blade.
May go to a friend's house and use his compound miter saw. Was hoping to avoid that trip. :(
Re: Two Questions
Dan Donaldson
>If you have any hand planes, you should be able to rough it in on the bandsaw and fine tune it with a plane.
Re: Two Questions
r payne
>How about a circular saw with a straight edge clamped to the piece?
George@Colonel's Workshop-Havertown, PA
>Good Morning Basil,
Do you have a table top or full size disc/belt sander? Since you can get the pieces almost right on the bandsaw, a sander can take the cut to the lay out line, sweetening the "almost right" piece to perfection.
George
