It's been one of those days!
Jim Orasky in Davenport IA
>I've been Trying to get a few turning projects (aka stocking stuffers) finished. Things are not going well!
Can you top this for a bad day?
1. Got my thumb a little to close to the nova chuck. Thumbnails are over rated - it will grow back.
2. Used a wire to burn in a groove to a wine bottle stopper. I thought I did it right, took some heavy gauage wire, added handles, then burned a nice neat groove. Then ouch - wire hot enough to burn wood will also leave a nice neat burn on two fingers when you grab the wire.
3. I cut down a Russian Olive Tree, last year. Thought I'd try to use
some of the smaller branch pieces to turn some ornaments. When I went to size the the rough piece in my SCMS, I did not have it stable enough and the blade kicked it out. Thought I got away scott free (all fingers and no damaged saw blade teeth) until I used the SCMS to trim a dressed 1X1 piece of maple. It too went flying. A closer look at the saw blade, 60 tooth 12" Tenryu, revealed the blade was bent.
I think I am going to call it quits for the day!
