about temperature and vinyl
Michael Dresdner
>Yes, temperature is critical in lacquer flow out. If you want to see marked changes in lacquer, simply warm it. Rules of spraying say that the wood, finish and air should all be at the same temperature and should all be at or above 70 degrees. If that is not possible, at very least make sure the wood and lacquer are as warm as possible. You can then take them out to spray, and bring them right back the second you are done spraying. Get the lacquer up to 80 degrees and you will see marked improvement in flow out.
Most lacquers these days are sold too thick for most spray situations, so you would benefit from substantially reducing the lacquer with thinner. Don't hesitate to reduce it fifty percent or more. There is no harm in that and it will make your job easier.
Don't set the fan too wide -- set it to where you get the best saturation throughout the fan. Spray with the gun about eight inches from the work. If you are not a skilled sprayer, practice on cardboard, not guitars.
As for whether or not you need vinyl sealer, it depends largely on what the guitar is made of. In the industry, vinyl is used to adhere to some of the synthetic plastic bindings, particularly the ones Martin uses, and to prevent rosewood from bleeding onto adjacent binding. If you are using cellulosic binding and not using rosewood, there is no real need for it. Incidentally, dewaxed shellac (Zinsser SealCoat) does the same two things and is much less problematic than vinyl.
