OT - House wrap as shop ceiling?
John E in SC
>I can't recall exactly, but I think I've seen mention in the past of someone using tyvek-type house wrap as a ceiling cover in an unfinished basement. My shop is in an unfinsihed basement, and it would be nice to cover the exposed insulation overhead, and I suspect the white housewrap would reflect light better and make it brighter. I could just staple it to the joists, and if I ever needed access to the pipes/wires overhead, it wouldn't be that tough to get to. It's also fairly cheap, and I think I could be done in a couple hours. My question is, anyone not of a reason NOT to do this? I wouldn't think moisture / condensation should be much of a problem w/ Tyvek, but I'd like to see what y'all think before I commit!
Thanks,
John
Re: OT - House wrap as shop ceiling?
JohnKJordan in East TN
>John,
Before we moved here to the farm, we lived for 30 years in a house where a previous owner had stapled heavy foil-backed paper to the bottom of the joists in the unfinished basement furnace room area. This reflected a lot of light and covered wiring, pipes, etc. It was easy to remove and replace when I ran new wiring and plumbing. We never had a moisture problem. I can't see how Tyvec would be much different, except it would be harder to temporarily remove (but cheap to replace entirely if necessary).
Lee Schierer - McKean, PA
>Your insulation will sag over time. What I did in my shop was to add 1/2" aluminum faced foam insulation board. I used nails with plastic disks attached to support the insulation board. The aluminum reflects a lot of light. If you used screws instead of the nails you could even take it down if you needed to get at something underneath.
Lee
>I have a giant roll of Tyvek. Actually, several. The DuPont plant where they make it is about four or five miles form here. An Employee got me some "short spins" probably twenty years ago and it has been an asset ever since. I have a roll about four feet wide hanging in my shed like a giant roll of paper towels. I use it for everything. Drop cloths, Covered a wall in may shop that was exposed insulation, put it directly over the framing in my shed under the siding, lay on it to work on the car, on and on.
So the answer is yes. You can put it on the ceiling. Dust may take to cling to it a bit, but at first it will be fairly reflective, better than what you have now. It will improve the performance of your insulation a little. If is burns it won't contribute much in the way of combustibles to the fire. (Not such a good idea with foam board). It is subject to ultraviolet degradation, so after a while you find that it is not so tough and eventually it will fall apart.
John Foster
>Try fabrene.com they make ceiling liner fabrics, more costly than Tyvek, but more features too.
