Need Some Design Input Please
Ken Krawford
>I want to build some bookcases to flank both sides of a window in a room with a sloping ceiling (See crude drawing). I'm having trouble deciding how to handle the top of the bookcase. Should I bring it straight across to meet the bottom of the half round window? Should it go up all the way to the ceiling? Other options? I'm having a hard time visualizing what would look best.
Thanks for any input.
Re: Need Some Design Input Please
Paul Waddle
>I have no idea how it would look,but I'd go to the ceiling. Its nice to have as much book storage as possible. Jmho.pw
steve mackay
>The bay window with flanking bookcases was my objective. I only have a slope one direction and its not as drastic as yours. Thing is I finally gave up on all the math involved with getting everything to look " right " and went with looking " true ". While I think your after a gable look running into the center I'm not sure it would look " true ". Just a thought.
Palladian Design
>The classic design approach would probably refer to Palladio. His design would bring the tops of the flanking cases to the bottoms of the semi-circles. It is a classic look that you see in architecture, especially with windows. Thomas Jefferson often used Palladian design as a referrence.
Tom
Al Stokka - Cambridge, Iowa
>Ken,
I would look at topping the bookcase with a semi circle to carry the roundy theme from the window.
Al
Marv
>Hi Ken,
I would think in terms of replacing the empty wall with a two piece bookcase that when put together would surround the window, even at the top of the rounded part. And perhaps use glass doors that resemble the shape of the window?
Marv
Mike Fitterling
>I recently built two bookcases for the same setup, except the ceilings did not slope. I made the top of each bookcase terminate at the bottom of the round portion of the window. These are eight foot tall. You can see where I scribed in the existing basemolding (was done at sides and backs) and then I made up maple basemolding to match and wrap the bases. Also added crown once installed. Don't count on the walls being stright and plumb; there is a �" wiggle room for scribing on each side where it touches the walls. Looked good once in; sorry I have not gotten any pictures of them installed yet.
Good luck with yours.
Mike
Re: Palladian Design
>Here's a variation on that idea. You would have to form up a couple curved tops, but it might work nicely. To really knit it together, though, you would want to have a center bonnet as well, outlining the Palladian window and joining the two side bookcases.
Just a thought.
Ellis Walentine, Host
>Your sketch is about the same as I was thinking Ellis. The outer curves would look good with the window plus the sloped ceiling. If there was a little distance between the book cases and the window the window would probably look better without being boxed in.
