reflectors, tracking, heat lamp *LINK*
JohnKJordan in East TN
>Ernie,
I worked in solar energy research for some time and our team developed a relfective solar system using parabloic reflectors and fiber optic cables to carry the light into the building. (Link below if anyone is interested.)
One problem for any solar system is the requirement for tracking as the sun moves. Without tracking, either the amount of light or the duration of the light is limited.
A concave (parabolic) mirror requires critically careful tracking and as you say, can concentrate light and produce dangerous heat. (Our system could cause a piece of wood to burst into flame at the focal point.)
A flat mirror would be best for your use since it would give you natural sunlight and warmth. However, the problem with a flat mirror is that it also must be tracked throughout the day (although the tracking can be somewhat less precise than needed for the parabolic). A flat mirror will not heat more than direct sun if only used when the sun did not naturally enter the window.
A carefully positioned convex mirror can give you light for part of the day without tracking, the time and coveraged based on the amount of curvature. However, the sunlight would be so dispersed it would add very little light and warmth to the desired spot. It certainly would not add enough energy to heat any one spot to a dangerous level.
Tracking is expensive and difficult to implement since the arc the sun travels through the sky changes daily throughout the year.
BTW, here's more than you ever wanted to know about tracking: tracking with a closed loop control system (where the tracker detects the sun with optical sensors and positions itself) is less complex than open loop but not as reliable. For example, it can get tricked by incidental light from reflections or a street lamp entering the sensor. In closed loop tracking the sun path for the entire year is encoded in the computer which makes all the adjustments, but for several reasons this can get off track and may require occasional manual recalibration. IMO, the ideal system uses closed loop with automatic open loop recalibration.
If you want a real mess outside your windows, you could position a number of non-tracked flat mirrors so each will direct the sun inside for a short time during the day! The light from each would move across the floor - it might drive the dog crazy!
For the dog's sake, I think it would be far simpler more elegant to suspend an electric heat lamp over his favorite spot and control it with a timer. A farm store carries bulbs made for keeping baby chicks warm. These make a mild, safe, heat.
some info about hybrid solar lighting
