Delta DJ-20 Update � PLEASE READ *LINK*
Paul Cates - Henderson, KY
>Hi everyone. I feel like an idiot�read on:
I posted on Monday about the problems I was having with my Delta DJ-20 jointer (see original thread in the link below). That post was a bit long (and so is this one), but to sum: it seemed that 6 of 8 set screw holes to lock the eccentric bushings in place were not drilled and tapped all the way through, thus making it impossible to lock the bushings which adjust the table height. I thought about fixing the problem myself (drilling and tapping the holes), but decided to call Delta to see if they would fix it since I assumed it was defective from the factory. One reason I called Delta was that if I broke a tap, then I�d really be up a creek, so to speak, because the piece of cast iron is over $600 on Delta's website. After several calls, I finally spoke with a guy (Fred) from Delta who was willing to send someone from a nearby authorized service center (Lensing Tool & Supply) to my house to fix the jointer. I called Lensing and decided to dismantle the jointer and take it to them to get quicker service and had it completely apart in about an hour and a half. It was a bit tricky to get apart by myself�I wonder how long it�ll take to put it back together? :)
I lugged the cast iron beast of a part to the back of my vehicle. Now that the tables had been removed, the set screw holes were much easier to access with a tap and handle. I finally listened to the voice in my head and took a 6mm tap and spun it all the way through to the bushing hole on the first �partially drilled� set screw hole�and the next�and the next. Oops. All holes were completely drilled and tapped at the factory, but the 6 I thought were not were merely full of metal cuttings.
There were several reasons I thought my jointer was defective:
1. I did not know there were 2 set screws for each bushing. After I bought the jointer, I was faxed a table adjustment procedure for the table adjustment for a Delta RJ-42, and hand-written on the fax was �applicable to a DJ-20.� In those instructions, it mentions a �set screw� not �screws.� That�s why I thought when I tightened the top set screw, I was tightening the ONLY set screw, thus contributing to my erroneous thought that the set screw holes were short. In Delta�s defense though, the parts diagram for the DJ-20 has a picture of 2 set screws.
2. I ran my finger in the bushing hole and did not feel anything where the set screw hole should be. I also stuck a small allen wrench in each hole but I guess I didn�t poke hard enough.
Kudos to Delta. They were willing to fix a jointer that is nearly 9 yrs. old based on my word alone. I will be calling them in the morning to apologize to Fred.
I�m VERY thankful that I discovered my error without wasting the time of a serviceman making a visit to my house. As it is, I wasted enough peoples� time. I felt so bad that I went to Lensing this afternoon and apologized to the two guys I spoke with�and gave each of them a pen I made. They were very understanding and appreciative of the pens. The good thing was that I got to hear some stories about other customers like me. :) They will get my business in the future.
Looking back, I should have run a tap in there to make sure I knew what I was talking about. Lesson learned.
I sincerely appreciate everyone�s suggestions and apologize for wasting your time. I hope I have not cost Delta any business�I have never had a problem with any of their machines.
Paul
Original Thread
Re: Delta DJ-20 Update � PLEASE READ *LINK*
Sean Troy
>I would bet something like that has happened to all of us at one time or another. No ones time is wasted when a question is asked.
Not to worry...
David Yoho
>There's no shame in learning something you didn't know. There's also no shame in making a mistake and admitting it. Your post might just help someone else avoid the same thing later. So, all's well that ends well. Thanks for sharing.
David
Good for you!
Charles R. Smith from Victoria
>Thanks for telling the rest of the story. When a company messes up, we can be quick to jump on them, but when we mess up and they do what's right, it is easy to forget that some employee has gone above and beyond the call of duty.
I appreciate the fact that the folks here on WC take the time to tell the happy stories about companies that make doing business a pleasure.
It was thoughtful of you to show that you cared, by your donation of pens. A nice Christmas gift! Good for you!!!
Re: Good for you!
Kevin Rabenaldt
>Don't be not hard on yourself. Afterall, the manufacturing process left the cuttings behind.
Kevin
Hey Charles...
HC Sakman
>I've got the Champix...! Thanks.
Chico...
Randy Johnson Connersville, IN
>"The good thing was that I got to hear some stories about other customers like me."
That's the whole thing in a nutshell. Having done a lot of service work over the years I've seen more than a few cases where the problem was obvious and easy to fix - sometimes it isn't even a problem to start with.
As a teaser, let me say that I would never post about what I consider the dumbest thing I think I ever did. There are too many people who know about it already.
There's a difference between....
David Yoho
>... Stupid and Ignorance. Ignorance can be fixed by learning - stupid can't!
I'm just glad none of you live near enough to me to see some of the dumb things I do on a regular basis! I don't have a problem owning up to or reporting dumb things I do. I just don't share that many here because there's not enough space on the whole Internet to publish them ;-)
David
At least you got us to think
Virgil Johnson
>about solving the problem. You got a better response from Delta's rep than I did.I'm impressed. I lost all faith in them when I described a problem with my jointer fence to a rep at the Indy show and he told me there was no way for that condition to exist. I ended up machining the fence myself to fix the problem.
I'm a little confused.....
>Why would you be embarrassed, chagrined, or whatever? You tried to work on your jointer and eventually discovered it should have had two set screws in each hole and not one. (Something I would not have known to look for and would have been dumbfounded about. I am a little embarrassed to admit I never heard of the concept of two set screws in the same hole.)
Eventually you find out the holes are packed with filings. You tore the machine apart to get to the point you could do that. There was no second set screw, even though by this time you knew there SHOULD be. So, for nine years you have been struggling with a machine that came from the factory with the holes packed with shavings and setscrews missing. (I'm wondering if the shavings weren't packed tight enough to partially hold the bearings in place?) But, in the end why would you be embarrassed? I think you have done remarkably well to find this and fix it. It was a "Two Fer", literally two problems on top of each other and you prevailed. Delta still gets the blame for shipping a machine in that condition and a little credit for being willing to help. (They should have been able to tell you over the phone that there were filings in the screw holes, you did not get the only jointer they made with tat problem.) Congratulations on a job well done.
PS, Did, you install the 2nd set screws?
if it helps any
Mike Schwing from Md.
>You're not alone in not knowing there are 2 set screws. I have a new Grizzly jointer and had the same initial problem. I removed the set screw and couldn't get the eccentric bushings to budge, period.
Only from searching around with Google did I accidentally discover the 2nd set screw - problem solved.
Bill White
>Alright. Just go out in the yard and smack yourself REALLY hard.
I've NEVER done anything like that before. Kudos to the Delta folks, and thanks for your update.
Bill
Chico, that's great!
>Hey Chico,
If Chantix helps you stop smoking, it'll be the best Christmas gift you could give to your family. I'm delighted for you!
Maybe Ellis will even give you a tee-shirt in celebration of your accomplishment. Do they come in your size??!?
Charles
Re: I'm a little confused.....
David Yoho
>I am now too. Didn't he say there were two set screws in there to begin with?
David
>Hi,
Yes, there were 2 set screws to begin with, but I didn't know about the second one until last weekend. After I removed the second one, that's when I thought the hole wasn't drilled through.
David Yoho
>Good, I thought I read that right.
David
My mistake......
>I should have reread the post. I thought there was no second set of screws, just crud under them.
Other than that, I stand by my statement that you shouldn't be embarrassed. Who would expect to find a bunch of crud under the crews interfering with their function? Again, Good on you for figuring it out and good on Delta for being willing.
Re: My mistake......
>Hi Barry,
No problem. I'm not the best writer in the world so I probably didn't explain myself very well.
Have a great holiday,
PC
Thanks Charles. Did you get my e-mail?
HC Sakman
>Thanks for everyone's support. The DJ-20 is back in one piece and I'll finish realigning the tables and setting the blades tomorrow.
If you haven't already, please keep WoodCentral in mind when making your holiday/year end donations...I'd hate to see this community disappear.
Happy Holidays,
PC
