Sprayer opinions wanted
Nat Robison
>Anyone have any opinions on the type of sprayer shown here? I've never sprayed anything before and own a 2 hp P-C pancake compressor.
I'm mostly interested in spraying paint and poly.
Nat Robison
Re: Sprayer opinions wanted
>That is the "Critter" and it will do an okay job on 2lb or less shellac or solvent N-C lacquer. It won't handle "paint", and will have a tough time moving poly even if drastically thinned. It will Not move waterborne or acrylic finishes.
What specifically are you trying to spray?
MM
Response
Nat Robison
>Primarily, I just want to have a better-looking painted finish on kids' furniture, etc. Until my skills improve, most of my lumber comes from Lowe's and Home Depot and I'd like to paint some pieces.
I've seen HVLP guns for roughly the same money but don't know if I have the compressor for it.
Re: Response
NickB
>Your 2 HP pancake will not keep up with any HVLP conversion gun that I know of. As the previous poster said, the Critter is good for very light bodied finishes.
I have a 12 gal "3 HP" compressor that keeps up reasonably well with my STM conversion gun (this is a small gun that is more generally considered a "detail" gun). I wouldn't even think of spraying paint with it, but it does a very nice job with wb finishes.
If you want to spray paint (particularly latex), look at an airless sprayer.
If you want to get an HVLP conversion gun, go to Jeff Jewitt's website and read the forum for while-it should give you an idea of recommended set ups for particular situations (and you can always post a question or give Jeff a call). A good HVLP conversion gun is not cheap, though, and they're pretty hungry for air.
Hope this helps,
Nick
Thanks
Nat Robison
>Thanks. I think my ultimate goal is to try spraying cheaply. There are plenty of other tools/machines I should probably get first to make the furniture better from the get-go.
It doesn't sound as though spraying is inexpensive to get into and I don't think I have the compressor for it right now.
Re: Response
David Yoho
>Nat, if it's a better painted surface you're after, and I assume you've been using a brush, there's a much, much less expensive way to skin this cat! Both the orange and blue Borgs sell 3" or 4"-long foam rollers and handles. These things are great for applying paint to projects and the end result looks much better and takes less time. Give them a try before throwing money done on something that isn't going to perform like you want. I think you'll be very surprised at your results.
David
Re: Can Do *LINK*
>Don't count on an HVLP unit the atomize a heavy body paint. If the gun would run, you'd need a special large tip to handle the paint and it takes AIR to bust up the stuff into an even mist. Those pancakes typically put out 2-4 CFM at 40 psi so are not not destined for success in that effort. It might, however, do a credible job with a base coat/sanding sealer situation. Once you get the wood sealed, spray can paint might do you for the color coatings, at least until you can put together a bigger compressor.
All that said, I've seen some hand-applied finishes that easily rival any spray job in the same material. I'd suggest you post your questions over on Jeff Jewitt's forums on the Homestead site.
Re: Thanks
Bill White
>Au contrair mon ami!!!! I have the Critter, and I have sprayed latex, enamel, shellac, poly, WB poly. Adjust the air pressure and the siphon, use Flo Trol or Penetrol, use a test pattern, then spary away. Great for small jobs.
Very easy to clean up. Best $40.00 I've spent in a while.
Bill
Second the motion...
doug f, san clemente, ca
>Nat - I'd add my vote for Mark's suggestion of using spray cans for your color coats. I've achieved some excellent results on small projects (where getting out the spray equipment was just too much trouble) by using Krylon or a similar spray, sanding carefully before painting and using mulitple light coats of paint. The result is very smooth with no runs, drips or errors.
Have fun with your project.
Doug
