REAL MILK PAINT
New Jatoba Staircase installed and finished (w/pic
David Eisan
>Hello everyone,
In the first two shots you can see the old staircase in the background through the old dining room doorway into the main hall. That was the day I took possession of the house. I had just started banging holes in the walls to see what was behind them before I went into full demolition mode and removed all the walls on the main floor. I knew the carpet was coming off the stairs, but I didn't know what was underneath them. It turns out the staircase was nothing more than dimensional lumber with carpet on it. Pretty low end. This would not fit in with my plans for the house.
Once all the demo, structural work, electrical rough in, drywall and new subfloor were in, I contacted a friend from work who owns a staircase company about a new staircase. He came over on a Saturday and Katarina and I talked with him for a couple of hours about what could be built. While the old staircase may have met code 30 years ago, simple dropping a new one in today would not. We would need one more tread. He came up with the idea of a platform at the bottom to get that additional tread. The old staircase had a wrought iron railing with a plastic cap that went on the outside and bent inward where the stair went into the ceiling and up to the second floor. After much discussion we settled on a design. A diminishing railing on the outside that would die into the ceiling, a full railing on the wall, square pickets and a panel newel post.
The stair case was supposed to take 4-5 weeks from order to install, but it took longer. It turns out you can not just go to one of those big square places and pick up a sheet of Jatoba plywood (for the risers). Once the custom sheet of Jatoba ply showed up, the staircase was finished and ready to be put in. I was out of town the day it was to be installed. I was eager to get home and check it out. Just the main staircase body was installed on the first day, it was 90%+ built off site. All the railing and trim materials had been milled oversize and were fitted on site over the next two days.
I then had to lay the tile in the entranceway, flooring on the two landings, finish the trim myself, prep and finish the staircase. I have never spent so much time on such small areas of flooring. I really am embarrassed to admit how long those two little platforms took. I bet half the main floor will not take as long.
I shot four coats of Magnalac pre-cat lacquer with a Kremlin HVLP system. A staircase is probably not the best spray project for a first timer, but it went well. I only had one run, which was caused by me bumping my head and stopping the gun. This was sanded down and fixed on the last coat.
I am very pleased with how things went and I could not be happier with the outcome.
I have some time off over the holidays and I hope to get a lot of the 1600 sq ft of Jatoba flooring out of boxes and down on the floor.
My plans to take a 30 year old house and turn it into a 80-100 year old open concept are taking shape...
Thanks for looking,
David.
Every Neighbourhood has one, in Mine I'm Him
Re: New Jatoba Staircase installed and finished (w/pic
Very handsome; great workmanship
Very nice work, Dave.
Eddie Pacheco; San Jose, Ca.
>The new staircase really enhances the new, more open entry.
I don't think there are too many finish carpenters that use Lee-Neilsen planes in there work. At least I think that's a L-N low angle plane in the picture there. post more pics of the house project when you get a chance.
Great job, Dave
>That jatoba really looks great, and it'll wear like iron. Congratulations on a beautiful job and for having the energy to complete it. :-)
Ellis Walentine, Host
Finish carpentry and LN planes
wilbur
>Nice work, Dave!
Tom Silva on This Old House uses LN planes. On last weekend's episode, he was demonstrating how to hang shingles on a splayed column, and used a LN bronze block plane (probably a 102) to trim the shingles. He's shown them on other segments about hand planes.
Amazing Work!
Jim Shaver Oakville, Ontario
>Hi David,
Amazing work my friend. I know we spoke briefly about the renovations you and your wife are making to your home, but I had no idea that it was this extensive.
The stair case transformation is outstanding...I can hardly wait to see what else you do in your home.
Merry Christmas,
Jim
Tom Silva's,
>Operating budget is a lot better off than most hardworking trim carpenters...:-)
Very nice work David.
HC Sakman
>It'll sure increase the value of this home.
Chico...
