Serpentine Front Desk - couldn't do it without WC!
Felix B
>Good afternoon everyone,
It's been awhile since my visits to WC � many-many reasons: moving, working, woodworking...
Anyway, to make a long story short - I finished a project that I've been building since February... I am posting few pictures just to give you an idea of why I had no time to be here :) I'll have a more-detailed write up for the shop shots in a week or so...
Now credits: WOODCENTRAL was a major source to answer all my design, construction, and all other 'how-to' questions for this project. Thank you everyone! Thank you Ellis and your gang for making it (Woodcentral) possible, you guys rock!
The materials are cherry, cherry veneered plywood (sequence matched) and poplar. The finish is 10-12 coats of General Finishes High Gloss Oil & Urethane (whiped-on). One of the goals of this project was to keep the construction detail level to the minimum, so attention can be on wood grain.
The top and sides of the pedestals is 3/4" furniture quality cherry veneer plywood (was not an easy task to find book/sequence matched cheets). The corners of the cabinets, leg bases, and edge around the top is solid cherry.
Another level of difficulty was added by having fronts of the drawers veneered so the grain is vertical. Vacuum press and bendable plywood (some call it italian poplar) were used to acheive the curved fronts.
This desk has 7 full extension drawers with the slides installed under the bottoms of the drawers. All drawers are dovetailed (for the strength) although the beading was added around the edge of the drawer fronts to cover the layered plywood edge and make drawers to stand-out a bit.
I ended up mitering the top's two corners to give it a "safer" look and feel..
Also, here are few links to old posts that made this desk possible:
Pedestal construction discussion
Sketch of desk construction
Drawer construction discussion
Thanks for looking, your thoughts, questions, and comments are welcome.
Sincerely,
Felix B.
Re: Serpentine Front Desk - couldn't do it without WC!
You done good!!!
David Yoho
>Felix, that is wonderful work! The finish looks great and the wood grain is an attention getter. I really like some of the subtle details I see. You can be very proud of this work and I know you'll enjoy using this beautiful desk.
I look forward to putting this one in Shop Shots for you.
Thanks for sharing,
David
George@Colonel's Workshop-Havertown, PA
>Good Afternoon Felix,
Obviously all the design and finishing work were not extemporanious. The desk is a tribute to all the sweat and tears you expended getting it all together into a perfect piece. Congratulations.
George
