OT Stretching Art canvas Questions
>My son made some frames (stretchers?) for art canvas for his girl friend. He bought canvas that appears to be fairly stiff, as if it is treated or sized. (As you can tell, I am clueless) He stretched the canvas and stapled it neatly around the edges, but it appears a bit loose to me. Someone said you wet it first and then staple find it shrinks as it dries and pulls itself taught. They suggest that his method will loosen even worse when she paints on it. Anyone know how this should be done?
Re: OT Stretching Art canvas Questions
JohnKJordan in East TN
>It's been a long time, but we always stretched unprimed canvas. When you apply gesso after stretching it tightens the canvas and it stays tight. If he didn't apply gesso afterwards, he should probably try that. I don't remember wetting the canvas first.
Also, did he use stretching pliers? It's very hard to get it tight enough by hand.
Is it loose in the center or at the corners? If at the corners, canvas should be stretched starting in the middle of each side, working towards the corners, and stapling on the back side. If loose in the center, is the frame bending? The frame must be sturdy (with joinery in the corners) to resist bending. If necessary, you can add cross bracing. Cross bracing is almost always needed on a large canvas.
Also try Google - a search for stretching canvas on frame put this at the top of the list - it looks like it has good information: http://www.artsparx.com/canvasstretching.asp
Start at the corners *LINK*
Charles R. Smith from Victoria
>There is an excellent article on canvas stretching which was recently published by Golden, a leading manufacturer (and researcher) of acrylic paints for the art community. This explains why canvas should be stretched starting at the corners and not the middle, because of the stresses placed on it. The procedure is based on research by preservationists. I've tried it, and much prefer it to the standard approach of starting at the middle.
Have your son suggest to his girlfriend that she download and read the recent issues of Golden's publication, "Just Paint". It is easily found at their website, which you can get from their link below.
Charles (who enjoys painting, but not as much as woodworking)
Golden - stretching canvas
David Yoho
>When my son was in his first year of art school at VCU, he made a 5' x 5' framed painting. We stretched and stapled the canvas to the frame and then he applied gesso. The gesso tightened the canvas and it's still tight now where it's stored in my shop.
David
Tony - Memphis
>My wife is an artist and I have helped her stretch a few. We use a set of canvas stretching pliers (good for upholstery work too). We start with raw canvas. I've always been a little surpised at how loose the canvas is, but she says that is correct. After a few coats of gesso, it does feel much tighter and of course it is stiff. I've examined some of the artwork we own and at galleries and found them to be similar to what we achieve, so I guess we aren't too far off. I bought an air stapler to try next as the electric stapler we have doesn't have enough power to sink the staples into the harder areas of the pine? stretchers. Haven't tried it yet.
Tony
