Wood floor finishing??
Tom Sweeney - Coatesville, PA
>I just want to make sure I've done things right before I put on the final coat of minwax high build poly & screw up all my hard work.
This is the first time I've refinished hardwood floors so bear with me.
I have drum sanded, dark stained & put the 1st coat of high build poly on my floors. As per the instructions I sanded after the 1st coat of poly. I rented a rectangular orbital pad sander & used 150 grit screen with a red pad behind the sanding screen. 150 was the finest grit they had & the rental guy said it would be fine. After sanding I wiped sown the whole floor with mineral spirits & then followed up with dry rags. Even after the cleanup there is still alot of cloudy white haze on the floors that won't wipe up.
I'm assuming the 2nd coat of poly will fill that all in & it will look fine, but I wanted to make sure before I did it. Will the fresh poly coat be OK applied with the white haze still there?
Thanks for any help - I want to put the poly on tonight if it's OK to do so.
