It's about time!
It's about time!
It's about time!
Lee Schierer - McKean, PA
>Here is a clock and weather station (see post below) I recently completed. The works and glass were from Klockit and the clock is styled after a kit they sell, but I developed my own drawing and dimensions for all the wood parts. There is a wood case behind what you can see that is octagonal on the top portion to enclose the works and rectangular on the bottom to enclose the pendulum. The door and face do not open. The weather sation instruments are also from Klockit, but the design is my own and was intended to complement the clock. The clock is about 22" tall and the weather station is about 13 inches tall. They are both made of red oak, stained with MinWax Golden Oak stain and finished with MinWax Polyacrylic semigloss water based wood finish. I think I have about 18-20 hours in the clock and weather station including finishing. They will be come wedding gifts for my nephew and his new wife later this year.
Re: It's about time!
Weather or not...
>Here is the weather station for the post above.
Lee
Re: Weather or not...
Greg Haugen
>Lee, very nice work!!
Greg
George@Colonel's Workshop-Havertown, PA
>Good Afternoon Lee,
I like the clock design especially, and have to admire the mitered joints. They look tight and true. How'd you do it? Is that a Hermle movement?
George
>The mitered joints were done on an adjustable angle sled. I cut all the pieces longer than the final dimension with both ends cut. I assembled the pieces to check the fit of all eight together. I had a stop on the guide bar to insure the lengths were all identical. After examining the fit I made slight adjustments to the set up until I had the angle perfect then did one last cut to trim all the pieces to the exact final length. It takes time, but the result is well worth the extra time.
The movement is electronic but it does have a Westminster type chime each quarter hour with an hour strike. The pendulum does work so it looks good. the chime on this particular movement isn't as good as the one I used on a previous clock and can't be turned off.
Lee
