What router,table and raiser to buy
Paul Waddle
>I should like to buy a new router table,possibly a new router(more on this)and router raiser. I have an old but good Makita 3hp square base router. Can use this router, or should I just buy the whole ensemble? On one of the forums,I can't remember which,there was a discussion on which to buy. They talked of the Q L, and the wood pecker PR..? Here is my need,I want to build a nice set of Kitchen cabinets, and I make my own picture frame moulding. I'm tired of making do with the old craftsman plastic case router in my aluminum craftsman portable table. I would like some one to lead me through to buying the correct set. If you will,give me the part numbers,names and approx cost. The best place to buy-maybe free shipping etc. Sorry for the length. I don't have to have the very best,just next to it. pw
Re: What router,table and raiser to buy
Patrick Schupbach
>Check out Woodhaven & Woodpeck.com for complete tables, lifts etc.There are numerous plans available to build a cabinet base as well. Good luck with your search!!
NickB
>Paul,
I think it is, in part, a balancing act between your time and your checkbook. I'm currently using an old 1 3/4 HP PC router in the PC aluminum router table, and am going to upgrade at some point, hopefully soon, as I've got a wainscotting project in the works. I ballpark priced buying everything for a system that allows for quick above the table bit changes (Woodpecker QL lift, table, legs, fence (Superfence), and Milwaukee 5625 router), and it comes to about $1K (yikes!).
If you've got more time, you could save $100 or so by making your own table, and maybe another $100 by making your own fence. Woodpecker recommends steel supports for their router tables, but you could build something pretty good out of 3/4" birch ply and save another $100 or so. Then, if you don't mind pulling the router out of the table to do changes (and adjusting height from below the table), you could mount a Milwaukee 5625 directly to a router plate and save $200 or more (Pat Warner suggests this on his website).
If you like your current 3 HP router, depending on the availability of your time and your tolerance for messing around with things, you can figure out a way to mount you current rounter to a plate and set it up for adjusting under the table.
Personally, I like the Milwaukee 5625 a lot (I have one I use for handheld work right now)-the smooth start works well, it has plenty of power, and the depth adjustment is superb. I like the idea of the Woodpecker QL lift for ease of use and not having to haul a big router out of the table whenever I want to change a bit (although those guys with that router show that I see on DIY every once in a while don't seem to have any problem with it). The Superfence is a good, basic fence that works with the Woodpecker table out of the box (I like what I've seen about the Lee Valley fence, but I don't know that it would work as easily with the Woodpecker table). I'm planning on buying the legs because I'm not willing to spend the time to build a cabinet (a shop-built cabinet would almost certainly work better than steel legs, but building the cabinet takes time away from actual deliverables).
Hope my thinking helps you with yours,
Nick
Paul Waddle
>Thanks for the response,but I don't have 1k to spend. I MAY be able to squeeze out half that. I really would like to buy a top ,use my router;possibly a fence. I can either make the base with steel legs or a cabnet. I guess I will just have to get on with it and see which direction and how far I want to go. Wood Crafters has a couple of units I like,but they are not inexpensive.
Perhaps I'm just not current on the prices. I will visit Woodhaven and Wood pecker.pw
Re: What router,table and raiser to buy *LINK*
Gqrrett in Victoria
>Hi Paul
I also have the Makita 3612c. Unfortunately, its shape severely limits the kind of lift mechanism availble.ionce most are dedigned for the round-bodied style, eg Porter Cable, Milwaukee and Bosch. JessEm has a model for non-round units.
Or, you could make your own lift with a few hours pleasant work and under $5 in parts. The link wil take you to a detailed article with lots of photos on how I made one for my Makita. There's also another much shorter article in that section on making a simple shaft lock for above table bit changes.
Making your own router table is a simple and satisfying project, as is making a sophisticated fence. You could then spend your cash on bits!
Cheers, Garrett
$2 Router Lift
