Removing wax from dining room table?
Gary Evans Tallassee, TN
>Hi all,
One of Beth's customer's has spilled some wax on her dining room table. She got most of it off, but I'm told there is still some residue.
Anything that can take off the residual wax without damaging the unknown finish on the table?
Thanks,
Gary
Re: Removing wax from dining room table?
George@Colonel's Workshop-Havertown, PA
>Good Evening Gary,
I'd try a little naptha/lighter fluid and a paper towel.
George
Carol - now in NC Nebraska
>brown paper bag and a warm iron
Naptha
Worth a try
David Yoho
>Try sprinkling the affected area with real cold water and then wipe it with the grain back and forth using #0000 steel wool - using only the weight of your hand - no pressure. This works with paste wax so I'd still try it. The idea is that the cold water will congeal the wax and allow the steel pad to remove it from the surface.
David
Re: What kind of wax? WD40
Al Stokka - Cambridge, Iowa
>Gary,
Under the assumption that it is candle was, use WD40.I use WD40 all the time to clean the remnants of candle was from glass containers so the container can be use for something else.
Al
>Thanks folks,
I suggested naptha. I just wanted somebody else to blame if she messes up her table. 8^]
Actually, I'm going to pass along all the suggestions and let her decide what to do.
Thanks,
Gary
