ductwork installation question
phil in NJ
>Hi,
A potentially really stupid question... I am installing dust
collection using among other things the Oneida Air 90-degree
elbows... the adjustable kind.
Many of the elbows are VERY stiff to adjust though. I banged
them around to no avail.
Is there some trick to making them a bit easier to adjust? I
hesitated to use lubricant like WD-40 or something like that,
but maybe I should?
Thanks
Phil
Re: ductwork installation question
Re: They are a bit "stiff"...
>I was in a similar situation a couple of months ago. I ended up taking a piece of scrap lumber and cutting it so it fit in one of the openings of the elbow. I then put some screws into the lumber through the metal. I clamped the wood into my vise and (wearing leather gloves) rotated the elbow into approximately the correct orientation.
It took me a couple of trys to get the correct orientation. If the screw holes are in the "outer portion", you can use the screw holes when you fasten them together. If they are in the "inner portion", they'll be covered up anyway. Hope this helps.
Re: Use a strap clamp
Stephen Roth (also in NJ)
>I had the same problem. I bought a pair of cheap strap clamps from Sears. They worked great and allowed you to adjust in small increments rather than trying to twist with all your might and then slipping 180 degrees.
